586,116 active members*
3,469 visitors online*
Results 1 to 11 of 11
    Nov 2014
    RFQ - Very simple design - plasma/laser
    dxf file attached
    I'm looking for a quote to make these. 200-400/month.
    Material: Steel
    Thickness: 1/8"
    The hole size doesn't really matter, they're just there as starter holes so I can drill them manually later. One or two with the holes will be enough as a drilling template.
    I've been having a very hard time getting a quote for this. Please don't hesitate to tell me if I'm missing some info..
    Aug 2010
    128
    Re: RFQ - Very simple design - plasma/laser
    Your jpg does not have any useful information
    Nov 2014
    Quote Originally Posted by abcmojave View Post
    Yes, it's there so someone can quickly see that it's nothing more than a triangle.
    Is the dxf file enough?
    Apr 2010
    64
    Hi vanlacke,
    The photo and dxf are clearly enough information. You're good man!
    Jul 2013
    26
    Hi,dear Mr.Vanlacke.For this thick steel.You have 3 choice.Kindly choose as you need
    1.Fiber laser.For this thick steel,it is the best quality of cut(or engrave).But it is very expensive.Usually need about 100,000USD for 500w fiber laser.
    2.YAG,it is another kind laser machine,but quality is not very good,even bad.Usually need 500,00USD for YAG machine.
    3.Plasma,it is an economic way for metal cut.The cut quality is not bad,only at the start point and end point,it is a little flaw.Usually need about 10,000USD for 63A Plasma.
    If u want the machine quote,or any question,just contact me.
    Phone/whatsapp:+18668926716
    Skype:Whitecoffee_alex
    Quote Originally Posted by vanlacke View Post
    dxf file attached
    Material: Steel
    Thickness: 1/8"
    Apr 2010
    64
    Would 11g steel be okay for this application? Says its 1/8" but in my experience it's generally .010" smaller or larger.
    Dec 2014
    Do you have an email i could send the Quote to?
    Jan 2015
    12
    You're looking at about a 20 second cycle time per piece on a turret punch plus a couple of minutes each to knock off the tabs and package. I haven't nested these yet to figure the material requirements and cost, but labor should run about $2-$3 each plus a $200 setup given the small quantities required per month.
    Edit: And as previously pointed out, you're looking at 10ga or 11ga which will be just over or just under 1/8".
    Mar 2008
    24
    We can water-jet these, de-burred including materials minus shipping for $5.35each. the 5 holes can be any size you want, but this is for 3/16" holes. we would require half in advance and half upon completion.
    Rick Lane
    Lane Manufacturing
    [email protected]
    505-319-7369
    Jan 2008
    2247
    These would be less than $2.50 each plasma cut, lower based on decent quantities. PM me for more details and a quote from a good supplier of plasma cut parts.
    Jim Colt
    Sep 2016
    Are you still purchasing these monthly and are you accepting any new quotes?
    dxf file attached
    Material: Steel
    Thickness: 1/8"
  1. Cut Ready Design work for your CNC plasma, waterjet, laser and routers.
    By custom dxf file in forum News Announcements
    Last Post: 09-11-2014, 05:04 PM
  2. Simple THC design
    By Volker in forum LinuxCNC (formerly EMC2)
    Last Post: 12-07-2012, 02:38 PM
  3. CNC LASER CUTTER/PLASMA/ROUTER DESIGN
    By protomate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-25-2008, 07:56 PM
  4. Simple Plate Design--Waterjet, Mill, Plasma, etc.
    By LateNight72 in forum Employment Opportunity
    Last Post: 10-16-2007, 11:36 PM
  5. Help with simple piston Design
    By inmemarcos in forum Mechanical Calculations/Engineering Design
    Last Post: 02-14-2006, 10:03 PM
