586,077 active members*
3,686 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS VF-2 w/ 30,000rpm spindle, any issues?
    Jun 2009
    41
    I am looking at buying a 2011 HAAS VF-2 with the 30,000rpm spindle. Has approx 4000 hours and has a TR210 4/5 axis table. Anyone know of any common issues? Things to look for? Good machine? Bad machine? I will be using it for some light duty, small hole drilling and milling, mostly plastic, alum, G10. I WILL inspect before buying. I currently have 10 Mazak verticals, but just need some more rpm's. Spindle multipliers are out of the question.
    Nov 2006
    490
    Re: HAAS VF-2 w/ 30,000rpm spindle, any issues?
    It seems the biggest issues with machines like that are related to the high-output spindle. Shops will buy them then skimp out on the tooling, leading to unbalanced problems down the road. I don't know why you wouldn't spend the "correct" amount of effort if buying such a specialized machine, but the haas techs say it's pretty common.
    I don't know if there's much way to verify that, though. Vibrations, bad sounds, etc.
    May 2012
    67
    I'm not a fan of the Haas 30k machines. They go through spindle belts and the drawbar will go bad long before the the spindle does, but the drawbar is "non-replaceable" so it requires rebuilding or replacing the spindle. Not many of these around.
    Thank you,
  1. EXCELLON 100,000RPM Spindle
    By boongza in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2011, 08:54 AM
  2. haas vf2 off set issues
    By duckslayer in forum Haas Mills
    Last Post: 01-19-2011, 07:55 AM
  3. 120,000rpm tachometer help
    By Smurf208 in forum Hobby Discussion
    Last Post: 06-08-2008, 05:09 PM
  4. VF-2 (15,000rpm) SPINDLE BREAKING PROBLEM
    By boodoowaa in forum Haas Mills
    Last Post: 02-13-2007, 08:08 PM
