586,114 active members*
3,376 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Mechanism techniques used for a high speed z axis
    Mar 2006
    58
    Dear all,
    I have built my cnc wood router machine using rack and pinion mechanism for X and Y axis and ballscrew mechanism for z axis.
    The machine is working perfect but i am looking for enhancing the z axis speed to diminish the working time.
    In other words:
    The X and Y axis can reach a speed of 5000mm/min while the maximum Z axis speed which can be reached is 700mm/min. for example when 3D fininshing a relief, the X and Y axis seem they are waiting the z axis while if it were able to move the same speed of X and Y , the working time will be reduced 10 times approximately.
    Therefore I plan to use the rack pinion mechanism for the Z axis and I bought a heavy duty stepper (holding torque 4.5N/m) and a driver board (200 steps per revolution TO 12800 steps per revolution) . The Z gantry weighs 10 kgs so the stepper can move it easily and 12800 steps/revolution gives me an acceptable high resolution.
    This is my plan but I prefer asking the experts before proceeding , there may be an alternative using multithreaded ballscrews giving the same speed??
    Thx in advance for your advice.
    Best regards,
    Baligh
    Jun 2005
    24
    Re: Mechanism techniques used for a high speed z axis
    Are you sure increasing the Z speed would increase your overall performance that much?
    If you look at the programmed feed rate vs the actual feed rate when Z is moving, is it really close to 1/10 of programmed?
    Depending on your current hardware, you could alter the gearing ratio on the Z axis pulley (unless it's direct drive), or get a stepper that can handle higher RPM, or replace the stepper with a servo motor.
    Going from screw to rack & pinion seem like a significant rebuild of the machine...
    Mar 2006
    58
    Thx dukerX for your reply,
    When 3d roughing with no change in Z , the machine is fast enough and at the same determined feed rate, but when there is a change in Z it slows . it becomes clear that there no consistency between x and y , and z.
    The z axis is driect driven, no pulleys installed , and may using gears heats the plastic nut (5000 rpm needed).
    I am now looking for a mutistart ballscrew for not rebuilding the z gantry in case of rack and pinion solution which will be my last choice .
    Mar 2006
    2712
    Possibly a linear motor? No ball screw or nut is required. Draw back is either a power-off brake or counter balance is need for safety.
    Dick Z
    DZASTR
  1. Spindle Speed Override: How to Implement?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-17-2014, 08:38 PM
  2. X-axis chatter at high speed travel
    By tjamscad in forum Fadal
    Last Post: 07-25-2012, 03:15 PM
  3. Replies: 10
    Last Post: 09-08-2007, 05:40 AM
  4. High Speed CMS FOAM 5-axis milling machine
    By fairlane77089 in forum Hard / High Speed Machining
    Last Post: 06-05-2006, 04:09 PM
  5. High-Speed 3 (4?) axis cnc router
    By rherman in forum DIY CNC Router Table Machines
    Last Post: 10-21-2005, 04:31 AM
