586,096 active members*
3,696 visitors online*
Thread: Brass Bolts
    Nov 2008
    16
    Brass Bolts
    Greetings,
    I am looking for replacement brass bolt as shown in the attached picture.
    They came from steel sash windows that we are restoring.
    It is 1” tall with a shaft of 0.35”
    I was wondering if anyone could suggest a supplier.
    Thank you in advance.
    Michael Mezalick
    Mezalick Design Studio, LLC
    Historic Stained Glass Restoration, Leaded stained glass repair , Church Windows
    Nov 2007
    479
    Re: Brass Bolts
    If you find a machine shop that has a live tooling lathe in your area, they can spit those out with a bar feeder pretty quick and easy.
  1. Using KRMx02 to cut Bolts
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 10-26-2013, 10:05 PM
  2. 1/2 unf bolts
    By ad1z in forum MetalWork Discussion
    Last Post: 05-29-2013, 10:55 PM
  3. Replies: 10
    Last Post: 01-16-2013, 06:52 AM
  4. Need dimensions for housing bolts (not mounting bolts)
    By rcpilot82 in forum Stepper Motors / Drives
    Last Post: 09-22-2011, 02:29 AM
  5. Weld Brass to Brass
    By piratesover40 in forum Welding Brazing Soldering Sealing
    Last Post: 03-04-2008, 01:02 AM
