586,103 active members*
3,512 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Setting to change cutter comp from Radius(R) to Diameter(D)?
Results 1 to 6 of 6
    Jun 2010
    26
    Question Setting to change cutter comp from Radius(R) to Diameter(D)?
    I'm circle-interpolating a lot of very tight-tolerance holes and it's quite maddening that the cutter comp page is in 'radius'. In 'radius' the minimum diameter adjustment I can get is 2 tenths (.0002) so when I'm trying to hold some bores with .0003 of tolerance, I have to wait until they're pretty much undersize before I can make an adjustment or they'll go over. Now I know on the HAAS control this setting can changed but I'm quite unfamiliar with the FANUC controller. Can someone please help me find this?
    pearls ain't free
    2932
    Re: Setting to change cutter comp from Radius(R) to Diameter(D)?
    It would help to know WHAT Fanuc control you have. The parameters aren't always the same.
    Jun 2010
    26
    We actually found the parameter but for some reason the changes won't take effect. How do I get the changes to stay?
    pearls ain't free
    2932
    Are you keeping the model of the control a secret?
    Jun 2010
    26
    I can't remember off the top of my head what they are, I want to say one is a Series 31 Model A, and two others are Series 32 Model A.
    pearls ain't free
    2932
    Quote Originally Posted by Cavi Mike View Post
    On the 30 series, there is a new [EXEC] soft key that should set the new value in the parameter.
  1. Using tool diameter for cutter comp
    By intenths in forum Surfcam
    Last Post: 02-20-2014, 03:32 AM
  2. Radius with cutter comp
    By KVD in forum GibbsCAM
    Last Post: 08-12-2009, 06:18 PM
  3. Need to use Cutter Radius Comp in G19 Plain
    By strider5623 in forum LinuxCNC (formerly EMC2)
    Last Post: 06-04-2008, 05:46 AM
  4. Can I adjust cutter comp diameter within a program?
    By davereagan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-20-2007, 05:12 PM
  5. Replies: 1
    Last Post: 02-21-2007, 10:57 PM
