586,555 active members*
3,401 visitors online*
Results 1 to 9 of 9
    Oct 2010
    30
    axis Y misalignment IN A PLASMA TABLE 5X10 FT
    HELLO GUYS
    A few months ago finalize my project in a plasma cutting table 5x10 ft, my compressor capacity was very small so I could only make continuous cuts of 3 minutes Now I have a compressor 80 gallon thing is very different there has been a great problem after 7 or 8 minutes of continuous cutting the y axis misalignment around 3/8" I tightened the screws on the gears and racks all is well fixed , I reviewed mach3 settings and everything is the same in the two motors that move the Y axis someone something happened thank you very much for your support
    add pics
    Attachment 256106
    Attachment 256104
    Jul 2005
    2415
    Re: axis Y misalignment IN A PLASMA TABLE 5X10 FT
    Turn the motors on
    grab one side and try to move it back and forth. Should have no play. Dot he same with the other. Any movement indicates something in the linear motion mechanics is loose
    If it is tight then try lowering the acceleration on both motors by 20% and run a test. Write a g-code test file that just moves the gantry back and forth a bunch of times and then returns to zero
    If you still have misalignment see if it always in the same direction and see if it is about the same everytime you run your test file. If it is you can try changing the steps per unit calibration on the axis that is wrong. Add or subtract steps or fractions of steps unit it goes the right distance.
    You can setup a dial indicator and move the gantry an exact amount and back on each side and see which one is the problem. Even a bad gear mesh can cause backlash
    Oct 2010
    30
    Quote Originally Posted by Torchhead View Post
    Turn the motors on
    thank you very much friend TORCHHEAD going to do these tests and keep you informed is very important for me to solve this failure to continue good service to my customers
    Jun 2009
    55
    I have often wondered, how do you fine tune a slaved motor? How are the steps set for the slaved motor? If the settings are only for the named axis "Y", what if this is not the correct steps per inch for the slaved motor?
    Oct 2010
    30
    hello friends;
    torchhead; Realize all your advice and exept the last I have not changed the configuration of the slave motor, I researched and I see that maybe this missing steps due to electronic noise what is your opinion ? tanks friends
    Jul 2005
    2415
    It is difficult to impossible to lose steps from noise since noise would ADD steps
    Oct 2010
    30
    tanks torchhead;
    it may be that the noise that this adding steps and for this reason misaligned?
    Oct 2010
    30
    news about my failure friends;
    I've noticed that when I do .tap code in the computer workshop, causes me this fault and when performed on my home computer all going great some friends could tell me i know the reason i use SHEETCAM
    tanks very much my friends
    Jun 2008
    562
    Maybe the post processor in Sheetcam has been modified on one of the computers. Make sure they are both the same.
    Mike
  1. PRL motorsports 5x10 plasma table
    By Prl motorsports in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-13-2012, 09:09 PM
