586,753 active members*
7,170 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > need help,electro craft ,Permanent magnet servo motor,Part No 0660-06-011
    Nov 2014
    please help me,
    now i have a EC electro craft corpration,Permanent magnet servo motor tach,Part No 0660-06-011,Serial No H02037,Date code 340.
    i want to use it , i want to the motor datasheet, it have four input line, that red, black, blue, white, how to link the power, how many volts? is it a dc motor.
    please tell me. thank you very much.
    24223
    Re: need help,electro craft ,Permanent magnet servo motor,Part No 0660-06-011
    ElectroCraft made many motors for OEM's so yours may be a custom version, The 660-07 is a 60v 4600rpm cont torque 122 0z-in dc motor, yours may have a tach which is not generally used now, I would guess that the red/blk are the motor pair and the blue/white are the tach.
    If the blue white pair come off the rear of the motor this points to the tach position.
    Al.
    Albert E.
    Nov 2014
    thank you very much , :cheers:
    24223
    You can confirm the voltage rating by rotating the motor a known rpm by external means and measure the voltage and extrapolate it for 4600rpm.
    Or apply a certain known voltage and record the rpm.
    Al.
    Albert E.
  1. Electro-craft E675 Servo Motor
    By H500 in forum Servo Motors / Drives
    Last Post: 01-22-2020, 10:56 PM
  2. Help identifying an Electro Craft Servo Motor with a Renco Encoder
    By kevlar129bp in forum Servo Motors / Drives
    Last Post: 06-24-2013, 08:09 PM
  3. Electro Craft Servo motor
    By sermys in forum Servo Motors / Drives
    Last Post: 04-15-2009, 06:57 AM
  4. permanent magnet planar motor
    By 971155804 in forum Linear and Rotary Motion
    Last Post: 12-16-2008, 09:15 PM
  5. Can use Permanent Magnet Synchronous Motor ?
    By tivoidethuong in forum Phase Converters
    Last Post: 07-06-2007, 03:10 AM
