586,051 active members*
3,641 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Chatter milling in X direction only
Page 3 of 3 123
Results 41 to 45 of 45
  1. #41
    Jun 2006
    2512
    Re: Chatter milling in X direction only
    Quote Originally Posted by mr_ping View Post
    You see that the table moves out 0.05mm when I climb mill and goes back if I stop the cut. When doing light passes it doesnt happen, and finish is good.
    It seems you already know the cause of the chatter.(chair)
    Phil
  2. #42
    Dec 2013
    18
    Is it reasonable ?
    Quote Originally Posted by philbur View Post
    Phil
  3. #43
    Jun 2006
    2512
    Is it reasonable ?
    Cutter load is not constant so if the table doesn't deflect under light load but deflects 0.05mm under higher load then a natural consequence would be chatter.
    you still haven't answered the questions:
    How old is the machine?
    How mach use has the machine had?
    Phil
  4. #44
    Dec 2013
    18
    The machine is from 1986.My guess is that it is well used over the years.
    Phil
  5. #45
    Sep 2013
    183
    My machine is doing this.
    I tightened my spindle bearings and it helped but not fixed it.
    Thinking to tighten the Y axis gib next. It's only noticeable during straight line X-only cuts while climbing. Silent in all other conditions.
Page 3 of 3 123
  1. Encoder counting correct in one direction, double in other direction?
    By nworroll in forum CNC Machine Related Electronics
    Last Post: 10-26-2011, 05:41 AM
  2. problem - milling direction
    By spaltiel in forum CamBam
    Last Post: 06-28-2010, 12:13 AM
  3. Replies: 2
    Last Post: 12-06-2008, 03:10 AM
  4. New Member looking for milling direction
    By Bondomatic in forum Canadian Club House
    Last Post: 10-06-2008, 01:52 PM
  5. v22 CAM: Control direction of milling path
    By tikka308 in forum BobCad-Cam
    Last Post: 03-09-2008, 03:49 PM
