586,102 active members*
2,601 visitors online*
    Apr 2011
    31
    Ez-Path 2 Axis Drive Fault
    Hi. I have been having some issues with our Ez Path 2 lathe. Here is what is happening, and usually on a threading cycle, is that when the z axis begins it's movement, everything stops and there is an "axis drive fault" message. This happens intermittently. The only thing I have tried doing is taking the BMDC board out and cleaning the contacts, to no avail. What else can I do?
    Thanks.
    Sep 2006
    95
    Re: Ez-Path 2 Axis Drive Fault
    sounds like you have a bad drive.
  1. Axis Drive Fault
    By rmetzger2 in forum Bridgeport / Hardinge Mills
    Last Post: 01-26-2017, 11:31 PM
  2. 760-22 axis drive fault
    By tstom in forum Bridgeport / Hardinge Mills
    Last Post: 01-22-2009, 03:30 AM
  3. SL-20 A-axis drive fault
    By metaltec in forum Haas Lathes
    Last Post: 12-28-2007, 03:05 AM
  4. Z Axis Drive Fault
    By jeremy_d in forum Servo Motors / Drives
    Last Post: 08-16-2006, 04:04 AM
  5. Axis Drive Fault
    By Bluey in forum DNC Problems and Solutions
    Last Post: 11-04-2004, 01:54 AM
