Hi Fellow Sprut users.
I have been setting up my first Tension Compression tapping routine in Sprut 8
I am tapping 1/4"-20 holes in 1/4" 1018 steel.
I have set up a hole machining routine to drill with a #7 bit in preparation for the 1/4"-20 tap.
I have then set up for 1/4"-20 tapping with the T&C but I simulate, I get a red error during the tapping sequence that says it gouges the part. Do folks who use at T&C tapper get this yet go ahead and run the program with the error or is there another approach that gets the green check during simulation.
I know that since the hole for the tap is a smaller diameter than the 1/4"-20 tap diameter is sending an error message but it seems weird that Sprut would have a tapping routine and still have this error message.
Thanks for any responses.
