586,655 active members*
3,549 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > Controller does not display 3D G-codes MultiCam 5000
    Oct 2008
    47
    I just started working with a MultiCam 5000 table.
    At work thay only use it for 2D jobb's. So they only have the Enroute 2D software.
    In my private shop, I use RhinoCAM 1, and Rhino 4, When I post a 3d(3 axis) relief to a .cnc file and open it in the MultiCAM controller,
    I see only a small dot/pixel on the hand controller display.
    When I open the CNC file in the "Jobb editor" nothing is displayed, I even tried to cut and paste the initial g-codes from G90 etc. from a 2d .cnc file that was produced by Enroute.
    Stil it would not display annything in the jobb editor.
    In RhinoCam I use the MultiCam post. RhinoCam support says, there is nothing wrong with the MulitCam post, only that I may have to change to positive tooldown. (tool down = +1)
    I did not dare to test it yet.
    Does anybody know anything about what could be causing the empty display?
    Thanx for the help!
    Jun 2010
    463
    Re: Controller does not display 3D G-codes MultiCam 5000
    Have you tried to set surface in the air and do a dry run.
    Oct 2008
    47
    I havent yet.
    I really wanted that job, so i dont want to take any chanses yet. With my own 3 axis table, I have experienced the tool going right through the table ones.
    I am in a dialog with RhinoCAM support, and when I changed the MultiCam-post in RhinoCAM to to Metric, i magaged to get visual resoults in MultiCam's "Job Editor" software.
    I might dare to trie a test run with that file.
    In order to make the RhinoCAM's MultiCam-post to work properly i then got these instructions from RhinoCAM support:
    "Thanks for the update. You can edit the post processor & make the following changes to your Multicam post.
    General tab : Change Metric code from G71 to G70
    Start/end tab make the following changes.
    Add G75 by inserting a line above M12
    Program End code
    Insert G98 P147 D1 after M22.
    Save the post processor & post the code."
    I am not shure If "G98 P147 D1" should be wrtitten separate lines, or on the same line.
    In separate lines I suppose, Il trie to do that, and/or ask them how spesificaly to do it..
  1. Multicam 5000 Jog Override
    By cncworkdork in forum Multicam Machines
    Last Post: 09-10-2014, 06:07 PM
  2. Probe for MultiCam 5000
    By ClassicDoors in forum Multicam Machines
    Last Post: 03-13-2013, 12:01 AM
  3. Multicam 5000 plunge issue
    By RodneyPierce in forum Multicam Machines
    Last Post: 06-07-2012, 08:44 PM
  4. Multicam 5000
    By scenic cnc9 in forum Multicam Machines
    Last Post: 01-26-2012, 06:20 PM
  5. NEED HELP - MULTICAM 5000 SERIES
    By loyedp in forum Commercial CNC Wood Routers
    Last Post: 09-21-2010, 04:08 PM
