586,108 active members*
2,995 visitors online*
Thread: On surface
Results 1 to 9 of 9
    Dec 2012
    57
    On surface
    Attachment 256848
    Attachment 256850
    I'm trying to route these F holes in an arched plate. This is a 3-D model. I am attempting to use the along curves function. I am using a 0.062 em. I want to step down approximately 0.031. The plate is 0.19 inches. So it should take seven passes to cut through.
    However for some reason it stops after one pass. And it looks like the toolpath is not following the plate arching
    I've done this before so I know it can be done.
    Any help would be appreciated
    Ken
    Dec 2012
    57
    Re: On surface
    Ken
    Dec 2012
    57
    Re: On surface
    I needed to enter the raise Z number
    Ken
    Dec 2012
    57
    Re: On surface
    Attachment 256854
    And then I learned it's better to use the curves on the top of the surface and put in negative number in the raise z
    Ken
    Dec 2012
    57
    Re: On surface
    Ken
    Dec 2012
    57
    Re: On surface
    Problem solved. We will see how this turns out in the real world.
    Ken
    Mar 2004
    1661
    Re: On surface
    Negative value or not depends on your 2D settings. Absolute vs relative...
    Dec 2012
    57
    On surface
    Oh I see now.
    see my next post
    Ken
    Dec 2012
    57
    Re: On surface
    I think the positive value raised z will work better now that I think about it. Because it will cut some air in the beginning but it will only lower the Z to the surface of the spoil board. The second way will cut into the spoil board is that correct.
    Ken
  1. 3D Surface Toolpath milling deeper than surface
    By moto1965 in forum Mastercam
    Last Post: 07-30-2014, 04:15 PM
  2. Surface over a surface problem
    By omnitech in forum FeatureCAM CAD/CAM
    Last Post: 10-20-2011, 03:42 PM
  3. Fillet surface to surface problem
    By vincent13 in forum Mastercam
    Last Post: 02-10-2011, 01:15 PM
  4. MX3 SURFACE TO SURFACE TRIM
    By 82rouled in forum Mastercam
    Last Post: 05-18-2009, 06:02 PM
  5. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
