587,006 active members*
2,964 visitors online*
Thread: Z changing
    Jan 2014
    19
    Z changing
    I noticed that my Z is changing, well the programs are running……doesn't do it on every part…about every 3 part run. I run the same program 15 times a day..?
    Aug 2011
    135
    Re: Z changing
    This is a very wide open statement. Couple things could be happening. Are you sure you aren't getting collar pullout? If you think you are truly loosing steps you can put an indicator in the spindle. 0 the indicator on the top of your table. A d then run a simple code of g0 z10 g0 z0 over and over you can put a g4 p1 after the z0. Watch the indicator as it runs over and over. Should return to 0 everytime. If not then you got bigger issues. Every single time I've thought my z was changing and getting inconsistent depths it was my own fault or collet pullout
    Sent from my SM-G900V using Tapatalk
    Feb 2007
    1538
    Re: Z changing
    Quote Originally Posted by mioduz View Post
    Yes that should expose the error - then you need to track it down to its source.
    I have had this and it was Stepper to Ballscrew coupling creep. If you take off the Z access cover and mark the positions with a white out pen and run that code again - if this is the issue you will see the positions shift.
    If it is not that it is still good to have these marks - as they should stay in line and can be checked in the future.
    Cheers, Keen
    Sep 2012
    1543
    Re: Z changing
    This could be happening on your Z
    https://www.youtube.com/watch?v=Pgx3G4TxIc4
    IF it's not that, watch this
    https://www.youtube.com/watch?v=z5hM7ORrGOg
  1. Changing the WCS
    By asafweis in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-17-2013, 05:35 AM
  2. Changing from 2D to 3D
    By LockTech in forum BobCad-Cam
    Last Post: 02-20-2011, 03:07 PM
  3. changing post
    By norcal matt in forum Mastercam
    Last Post: 12-16-2010, 08:12 PM
  4. Changing the postprocessor
    By Arjan in forum PTC Pro/Manufacture
    Last Post: 12-07-2010, 07:10 AM
  5. Changing CS
    By fastolds in forum GibbsCAM
    Last Post: 02-02-2005, 07:31 AM
