Re: 5V Signals to 24V Signals Converter
On of the easiest ways is to use a simple 24v supply, you don't necessarily need regulated supply, then use either individual method using a 2n7000's between the P.P. and the drive, or in a ULN2003 in one unit.
The inputs to the drive can be set up in sink or source method, in your case the 2n7000 etc would be sink mode and the drive would be in source mode.
Al.
Albert E.
