586,096 active members*
3,667 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > FAULT MEMORY arrow 500 CPS 3500 FNC
    Mar 2014
    6
    Hello Friends.
    I have a problem with CPS Control cincinnati arrow 500 3500 FNC, this will exhaust the battery when it was turned off and I lost the data and throws errors when starting the machine.
    ERROR: FILE SYSTEM 9063 STATIC RAM CORRUPTERD
    ERROR: ERROR 9070 FORMAT DRIVE
    ERROR: FILE OPEN FOR 9044 cannont READING MAIN.PLC
    AND THEN LEFT IN SIMULATION MODE, BUT LET ME DO ANYTHING FROM CONTROL
    HOPE CAN HELP ME
    greetings from Chile:cheers:
    Mauricio
    Attachment 256916
    Dec 2006
    584
    Re: FAULT MEMORY arrow 500 CPS 3500 FNC
    I would say that you have lost part of the memory in the control. The memory needs to be replaced. Do you have the software to replace it and the procedure ??? Look at the posts for this same problem.
    Mike cncmachineservices (dot) com
    Apr 2007
    2580
    Mauricio,
    If you cannot find the information I used to have the same machine with the CT control from Emerson Control Techniques. I have the files to reinstall the firmware into the hard drive as when my machine came to me it had dead batteries in it. The only issue is I am not sure what version of the software I have or whether or not it is the same as yours. My machine is a 1997 model and it worked on mine. I have since retrofit the machine to LinuxCNC and all brand new electronics so It has been awhile since I did this. There is a file that describes the process tho. Good luck. Peace
    Pete
  1. Arrow 750 Z axis fault
    By Ivan57 in forum Cincinnati CNC
    Last Post: 03-26-2012, 08:52 PM
  2. arrow 750 z fault problems
    By chaz6966 in forum Cincinnati CNC
    Last Post: 11-26-2011, 02:14 AM
  3. spindle drive fault Arrow 500
    By scudzuki in forum Cincinnati CNC
    Last Post: 11-12-2010, 02:36 PM
  4. Memory loss on ARROW 750 need it back
    By ckwood in forum Want To Buy...Need help!
    Last Post: 07-09-2009, 08:27 PM
  5. Arrow 500 Drive Fault Error
    By macmub in forum Cincinnati CNC
    Last Post: 06-02-2009, 06:46 AM
