586,123 active members*
3,302 visitors online*
    Nov 2014
    5
    Wiring voltage divider
    Need help wiring a voltage divider to turn 24 volts into 5v. Since my breakout board only takes a 5 volt input how would I go about doing this. I found a cheap voltage divider on Amazon. I need to wire it to a 3 wire prox black, brown, blue wires. The prox gets 24v, but I need to regulate it down to 5 on the signal side. Any help you could give would be great.
    Jun 2012
    108
    Re: Wiring voltage divider
    Not knowing how much current your 5v break out board needs, it make it hard to answer. If it not very much I would use a wall plug that has a power supply that puts out 5V.
    something like this Wilson AC/DC 5V Power Supply w/ Mini USB Jack Sleek Mobile Pro/DataPro(859969) from Solid Signal
    24221
    Can you not get if from one of the 4 pin plugs on the PC P.S.?
    What is the 5v supplying? If you have a power transformer in the system you could wind around a few turns on, 10 turns should do it with a bridge rectifier and cap.
    There is also the cheap wall-wart type, these are now regulated supplies.
    Al.
    Albert E.
    Apr 2005
    17
    He needs a level shifter from what I understand. OP has a 24v proximity switch that has a pnp output. Use a resistor network...6.2k & 1.6k.
  1. Builiding a Voltage Divider
    By mconstrain in forum Waterjet General Topics
    Last Post: 02-27-2020, 03:50 AM
  2. Voltage Divider
    By piperpilot in forum CNC Machine Related Electronics
    Last Post: 11-28-2011, 04:35 PM
  3. Voltage Divider
    By MAS in forum CNC Machine Related Electronics
    Last Post: 09-10-2010, 12:47 AM
  4. new control board wiring: multi-voltage input
    By nicanor76 in forum Stepper Motors / Drives
    Last Post: 07-19-2008, 10:49 AM
  5. Voltage Divider methods?
    By rainman in forum CNC Machine Related Electronics
    Last Post: 02-13-2008, 01:37 PM
