586,070 active members*
3,518 visitors online*
    Dec 2010
    32
    4th Axis Information Please
    I have been getting familiar with 3 axis CNC work in metal and wood and would like to add a 4th axis. My controller will handle 5 axis. I see 4 axis stuff on ebay that look like lathes. Is that the only setup? Is the 4th axis A or B (as in XYZAB)? Anything I should look out for when purchasing a 4th axis setup?
    Nov 2014
    Re: 4th Axis Information Please
    Are you using a general purpose cnc lathe machine or other kind of CNC machine? for different kind of machine, the definition for 4th axis will be different, such as the CNC turn lathe and CNC machining center.
    Dec 2010
    32
    I am using a home made CNC based on a 24"x36" frame from mekanikacnc.com/ so I think the right answer is i am not using a lathe type CNC.
    Jul 2009
    419
    I use my 4th axis in a- and c-setup, both for indexing and lathe work.
    I think that you need to get used to only seeing the profiles in xyz and nothing in a or c.
    If you run more then one profile in one program things can get mixed up easily.
    Sven
    http://www.puresven.com/?q=building-cnc-router
  1. Looking for information about CNC's
    By ShinedBrass in forum Australia, New Zealand Club House
    Last Post: 04-30-2011, 02:15 PM
  2. Arrow/Saber Spindle and axis drive information
    By MKC in forum Cincinnati CNC
    Last Post: 09-22-2010, 06:23 PM
  3. Too Much Information!!!
    By HLF Ordnance in forum Benchtop Machines
    Last Post: 11-02-2009, 08:06 PM
  4. For your information...
    By Protobyte in forum Tormach Personal CNC Mill
    Last Post: 12-03-2006, 02:29 AM
  5. Information
    By Davey in forum MetalWork Discussion
    Last Post: 05-04-2006, 12:00 AM
