586,493 active members*
1,473 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > New Allegro Bipolar Stepper Driver A3986
Page 1 of 42 12311
Results 1 to 20 of 826
    Mar 2004
    75
    Credit for this link goes to slp_prlzys who posted it to General Electronics Discussion
    This is posted to Open Source Controller boards as I hope it will be picked up and developed quickly
    Allegro has a new Bipolar Stepper driver chip that drives N-FETs in a bridge configuration.
    You can buy them now at Digikey for about $5.00
    The chip includes high and low side drivers. - No IR interface chips required.
    Look here
    http://www.allegromicro.com/sf/3986/index.asp
    A3986
    Dual Full-Bridge MOSFET Driver with Microstepping Translator
    Features
    * 2-wire step and direction interface
    * Dual full-bridge gate drive for N-channel MOSFETs
    * Operation over 12 to 50 V supply voltage range
    * Synchronous rectification
    * Cross-conduction protection
    * Adjustable mixed decay
    * Integrated sinusoidal DAC current reference
    * Fixed off-time PWM current control
    Description
    The A3986 is a dual full-bridge gate driver with integrated microstepping translator suitable for driving a wide range of higher power industrial bipolar 2-phase stepper motors (typically 30 to 500 W). Motor power is provided by external N-channel power MOSFETs at supply voltages from 12 to 50 V.
    This device contains two sinusoidal DACs that generate the reference voltage for two separate fixed-off-time PWM current controllers. These provide current regulation for external power MOSFET full-bridges.
    Motor stepping is controlled by the two-wire step and direction interface, providing complete microstepping control at full-, half-, quarter-, and sixteenth-step resolutions. The fixed-off time regulator has the ability to operate in slow-, mixed-, or fast-decay modes, which results in reduced audible motor noise, increased step accuracy, and reduced power dissipation.
    The translator is the key to the easy implementation of this IC. Simply inputting one pulse on the STEP input drives the motor one step (full, half, quarter, or sixteenth depending on the microstep select input). There are no phase-sequence tables, high frequency control lines, or complex interfaces to program. This reduces the need for a complex microcontroller.
    The above-supply voltage required for the high-side N-channel MOSFETs is provided by a bootstrap capacitor. Efficiency is enhanced by using synchronous rectification and the power FETs are protected from shoot-through by integrated crossover control and programmable dead time.
    In addition to crossover current control, internal circuit protection provides thermal shutdown with hysteresis and undervoltage lockout. Special power-up sequencing is not required.
    This component is supplied in an 38-pin TSSOP (package LD). The optional lead (Pb) free package (suffix –T) has 100% matte tin leadframe plating.
    Mar 2005
    Red face
    This is a tough one!!! In a combination with IRF540 brings up to 10A at 50V which is quite enough power even for bigger steppers. Next week I will start prototyping my board. The only thing that is still missing is current limiter to approx. 25-30% when no step signal is detected.
    Cheers
    Jun 2003
    3312
    This is the part I mentioned a earlier in the year I was going to wait for. I've been working a compatable design compatable with the other designs on my website for about 2 weeks. Have the 3986 parts in hand, those tssops are small. Most all smds. Cant see a non soldermasked board as buildable. Layout is a bear!
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Mar 2004
    120
    Nice chip, just finished a layout for the first prototype
    with room left for a midband resonance compensation
    circuit. My plan is to test the driver board separately
    and switch in the compensation circuit afterward to save
    on prototyping costs.
    A hint for the curious... the compensation circuit consists
    of a bandpass filter and a voltage controlled pwm 555.
    more to follow,Gary
    embrace enthusiasm to accomplish the task
    Gary Davies... www.durhamrobotics.com
    Mar 2004
    75
    Start of prototype board
    Here is an update on a A3986 board
    All components are regular thru hole except the A3986 TSSOP
    I am gathering parts so my final may change depending on the parts I am able to buy
    I use Target layout - I don't have eagle files
    Any improvements or ideas appreciated.
    FYI
    Any other good ideas appreciated
    Mar 2004
    120
    with your placement of the fets... it will be
    difficult to use heatsinks.
    regards
    Mar 2004
    75
    Quote Originally Posted by DR-Motion View Post
    regards
    I have a bag of clip-on heat sinks that slip on the TO220 chips
    The clip on heat sinks are very versatile.
    I would like to use the back to back FET setup like Gecko but the prototype board was set up the way it is to use the simplest and most direct connection from the Allegro chip and the FETs.
    After I get the chip up and running, refinements will follow.
    Cheers
    Jun 2003
    3312
    Among others, your FET current paths and sense resistor arrangement is a problem.
    Mar 2004
    75
    Quote Originally Posted by pminmo View Post
    Please explain your improvement ideas.
    I would like to fix it on paper before I commit it to the boardmaker.
    Jun 2003
    3312
    You have to take into consideration high current paths and where to sense the voltage developed across the sense resistor. Same for grounds, motor supply, clamping........... low impedence signal drives, noise immunity.
    Right now I need to finish mine, it's laid out, passes all my rules, just need to spend some time reviewing everything.
    Mar 2005
    @DR Motion.
    Can you please explain the things about midband resonance compensation, I would be glad.
    Cheers
    Feb 2005
    130
    Quote Originally Posted by Azrael
    Here explanation is...
    http://www.cnczone.com/forums/showpo...0&postcount=30
    Here, starts of my projects
    Add something else ?
    Jun 2006
    7
    Add something else ?[/QUOTE]
    I think, diodes missing on h-bridge for each mosfet.
    Feb 2005
    130
    Quote Originally Posted by tmobile12345
    MOSFET have diode...
    and
    A3986 have SR - synchronous rectification mode....
    Quote Originally Posted by allegro
    ...eliminates the need for additional schottky diodes
    Jun 2006
    7
    Ok, You have right. Do you think use Irf540 or something else?
    Mar 2005
    339
    Do you have the board layout? Maybe in eagle format?
    Thank you.
    Zoltan
    Feb 2005
    130
    irf540 25A/80V Rds(on)=0.077R Qg(tot)=38-59nC
    irfz44n 49A/55V Rds(on)=0.0175R Qg(tot)=63nC
    irfz24n 17A/55V Rds(on)=0.07R Qg(tot)=20nC
    -->> IRFZ24N
    Quote Originally Posted by zoltan
    I'm working on that...
    yes...
    Mar 2005
    339
    Thank you for reply. I am interested in it. Are you going to share it?
    Thank you.
    Zoltan
    Feb 2005
    130
    yes... I'm going...
    now, I'm going to make good layout of pcb...
    Mar 2005
    339
    OK. Thank you. I am waiting for your pcb.
    Zoltan
Page 1 of 42 12311
  1. Allegro stepper driver
    By EUnit in forum Stepper Motors / Drives
    Last Post: 01-05-2011, 06:29 PM
  2. A3985/A3986 5A/50V Bipolar Stepper Design
    By NE5534 in forum Open Source Controller Boards
    Last Post: 09-23-2010, 05:39 PM
  3. Allegro A3986...Stepper Translator
    By slp_prlzys in forum CNC Machine Related Electronics
    Last Post: 06-07-2009, 07:59 PM
  4. Allegro A3986
    By Kevint in forum Stepper Motors / Drives
    Last Post: 12-07-2008, 07:53 PM
