I have lost the original schematic, but the current just folds back IOW the current will be restricted to what ever the limit is set to. Obviously this will affect the voltage out also if a very low R. load is connected.
If a PWM output was used then the voltage could remain at the set level and the mean current would vary, but with some loads, a PWM signal is not desirable.
But there is not much point in maintaining the voltage if the current cannot be sustained.
I was looking for semi-intelligent battery chargers a while ago and came accross this one.
http://www.angelfire.com/electronic/hayles/charge1.html
MicroChip have some designs also if you want to go the µProcessor route.
Al.
Albert E.
