586,357 active members*
3,394 visitors online*
    Sep 2014
    Text Write Wizard
    Im using Write wizard and it´s working properly. I want save produced g-code for future use. In mach3 i go to edit g-code and then save the code SaveAs with different name like mytext.tap.
    Next time I start Mach3 and loading g-code named I did save, the text is loading but it comes some swirls, like rounds too. The swirls is visible in g-code and graphigal window.
    What goes wrong ???
    Re: Text Write Wizard
    You're IJ mode is incorrect.
    Sep 2014
    Thanks !!! ger21 It was very good tip about IJ-mode. Good tip and little study for me about IJ modes.... great !
    I did make IJ-mode commands to g-code and works fine. Needs G90.1 with files from Write Wizard (other way is the init string in general config, but i dont know what happends my other files.
  1. How do I write a wizard for mach 3?
    By dtimes in forum Mach Wizards, Macros, & Addons
    Last Post: 02-13-2012, 12:26 AM
  2. Mach 3 write wizard
    By Jig Maker in forum Engraving Machines
    Last Post: 03-02-2011, 07:14 PM
  3. Write Wizard Help!
    By ibuildstuff4u in forum Mach Wizards, Macros, & Addons
    Last Post: 08-12-2009, 06:25 AM
  4. Write wizard and text misalignment
    By bgolash in forum Mach Wizards, Macros, & Addons
    Last Post: 04-27-2007, 12:22 AM
  5. Mach 3 Write Wizard
    By rweatherly in forum Mach Wizards, Macros, & Addons
    Last Post: 12-18-2005, 11:25 PM
