586,061 active members*
4,602 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam Peck Drilling
Results 1 to 8 of 8
    Sep 2014
    I have to drill very deep holes, up to 12 inches. I start with a 4" drill, then an 8" and finish with a 14". I would like to start the longer drills at the depth that the previous drill finished, but I can't get the peck to retract to the top of the part. For example, if I use my 4" drill to a depth of -3.5", then start my 8" drill at -3.45", my 8" drill will retract between pecks to -3.45". How can I get it to retract to 0?
    Thank for your help
    Dec 2008
    3109
    Re: Mastercam Peck Drilling
    What diameter of drill ? , Material ?
    Machine & Control ?
    A canned cycle may not do what you want, you may have to have it output longhand
    - some later controls do have that functionality of what you are needing. But I think you are stuck with doing it longhand
    Jul 2009
    86
    If it is a HAAS machine you could try adjusting setting 52:
    Rapid into a Hole on a Mini Mill | Haas
    Sep 2014
    Thanks for your responses. Changing Setting 52 seems to be the best fix for me right now. I'm currently talking with my Mastercam distributor to add a custom drill cycle.
    Use the depth of the last drill as the top of your "part", retract a small amount above that, what ever you like, and use the clearance plane option to retract out of the hole. Do this all the time. No need for custom anything.
    Feb 2014
    67
    Dec 2014
    17
    I can suggest this configuration for drill holes capacity in drilling machines and tools.
    # Hole up to 12 to 15 inches in start
    # Attached drilling pipes
    # Drilling depths/pecks in between 3.45 to 4.12
    Dec 2014
    17
  1. Combining peck drilling cycle with deep hole peck
    By adams4182 in forum G-Code Programing
    Last Post: 07-28-2013, 09:07 PM
  2. peck drilling
    By t300 in forum Visual Mill
    Last Post: 03-18-2013, 10:17 PM
  3. peck drilling?
    By Tristar500 in forum BobCad-Cam
    Last Post: 01-20-2010, 08:25 PM
  4. Peck Drilling
    By RBrandes in forum Haas Mills
    Last Post: 06-19-2007, 01:03 AM
  5. Peck drilling
    By LarryMiran in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-23-2004, 11:12 PM
