586,061 active members*
4,345 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > What's the difference between the 1010-1 and 1010-4?
Results 1 to 7 of 7
    Oct 2006
    79
    Hello,
    I have to replace a controller card on my 93 88hs. It currently has a 1010-4 card. Unless I misread the interchange chart (always a possibility) either would work in my mill. The 1010-1 is cheaper but I don't want to lose functionality. Could you tell me the difference between the 1010-1 and the 1010-4?
    Thanks, Shepard
    Oct 2006
    79
    Re: What's the difference between the 1010-1 and 1010-4?
    oops, I think I did misread the interchange chart. I have a 1400-4 CPU so 1010-1 won't work.
    Apr 2005
    1194
    From 1992 up to the early part of 1994 fadal used a 1400-4 card with -3 software. You can use a 1010-4 up to a 1010-6 but not a 1010-1.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Oct 2006
    79
    Thank you. Other than the jumper is there anything I need to do to swap in the new card? Seems I remember something about parameters being stored on cards... Ill look it up but if you know off the top of your head I'd appreciate it.
    Are you Shepard629 on ebay? i just sold a 1010-4 today.
    Oct 2006
    79
    Yep, thats me. Sorry I didn't catch your post. Its been a bit since I visited the forum. About to install the card and see if I can get running again.
    I forgot to pull the eproms, replace eproms with yours and reset jumper for your axis
  1. Replies: 2
    Last Post: 06-26-2014, 02:07 PM
  2. Looking for 1008 or 1010 low carbon steel
    By orangelss in forum Want To Buy...Need help!
    Last Post: 05-11-2011, 06:34 PM
  3. Milling Slot in 1010
    By gpraceman in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 06-24-2010, 01:41 PM
  4. XYZ 1010 with Siemens 810D
    By Haydn in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 05-19-2010, 05:34 PM
  5. A16B 1010 0040
    By gglynn81 in forum Fanuc
    Last Post: 05-18-2008, 04:02 AM
