586,318 active members*
3,732 visitors online*
    Nov 2014
    74
    Question arc data error
    Hoping i can get some help very new to all this trying to learn myself i have 2 programs i have altered fron the origanal first is a dogbone with a reduced section i get arc datta errors when i try to run it i have ran it in g wizard in the simulator and runs fine no problems, im running a mazak 430-A the first g-code is for the dogbone the second will be for a simple 1 1/2" sqaure which i took from a 3" i use and just reduced it thanks in advance i will also post the origanl g codes in the same order as the fist 2
    (dogbone with reduced section)
    G17 G20 G40 G80
    G90 G54
    M6 T1 (scribe)
    G90 G0 X1.1 Y-0.625
    G0 Z1.0
    S1000 M3
    G1 Z0.35 F25.
    X1.
    Y0.625
    G0 Z1.
    X-0.9 Y-0.625
    G1 Z0.35 F25.
    X-1.
    Y0.625
    M6 T2 (cut)
    M3 S930
    G90 G0 X6.25 Y-1
    G0 Z0.8 M08
    G1 G41 X5.625 Y-1 D2 Z-0.875 F5.
    X1.9364 G1 F12.
    G3 X1.275 Y-0.75 I-0.6614 J-1
    G1 X-1.275
    G3 X-1.9364 Y-1 I0 J-1
    G1 X-5.875
    G1 Y1.
    G1 X-1.9364
    G3 X-1.275 Y.75 I0.6614 J01
    G1 X1.275
    G3 X1.9364 Y1 I0 J1
    G1 X5.875
    G1 Y-1
    G1 X5.5
    G0 Z10. M9
    G0 G40 X0 Y3.5
    G91 G28 Z0.
    G91 G28 Y0.
    G90
    M30
    (1 1/2 sqaure)
    G40 G80 G90
    G91 G28 Z0
    G28 Y0
    N1(1/2 END MILL )T2 M6
    G54G90
    S1500 M3
    G0 X-1 Y0.
    G43 Z2.
    Z.394 M08
    G1 Z-.875 F5.
    Y-.750 F12.
    G3 X-.750 Y-1 I.25 J0.
    G1 X.750
    G3 X1 Y-.750 I0. J.25
    G1 Y.750
    G3 X.750 Y1 I-.25 J0.
    G1 X-.750
    G3 X-1 Y.750 I0. J-.25
    G1 Y0.
    G0 Z2.M9
    G91 G28 Z0
    G91 G28 Y0
    G90
    M09
    origanl files which run no problem
    dogbone reduced section
    G17 G20 G40 G80
    G90 G54
    M6 T1 (scribe)
    G90 G0 X1.1 Y-0.625
    G0 Z1.0
    S1000 M3
    G1 Z0.35 F25.
    X1.
    Y0.625
    G0 Z1.
    X-0.9 Y-0.625
    G1 Z0.35 F25.
    X-1.
    Y0.625
    M6 T2 (cut)
    M3 S1550
    G90 G0 X6.25 Y-0.75
    G0 Z0.8 M08
    G1 G41 X5.625 Y-0.75 D2 Z-0.875 F5.
    X1.9364 G1 F12.
    G3 X1.275 Y-0.5 I-0.6614 J-0.75
    G1 X-1.275
    G3 X-1.9364 Y-0.75 I0 J-1.
    G1 X-5.875
    Y0.75
    X-1.9364
    G3 X-1.275 Y0.5 I0.6614 J0.75
    G1 X1.275
    G3 X1.9364 Y0.75 I0 J1.
    G1 X5.875
    Y-0.75
    X5.5
    G0 Z10. M9
    G0 G40 X0 Y3.5
    G91 G28 Z0.
    G91 G28 Y0.
    G90
    M30
    origanal 3"
    G40 G80 G90
    G91 G28 Z0
    G28 Y0
    G54G90
    S1500 M3
    G0 X-1.75 Y0.
    G43 Z2.
    Z.394 M08
    G1 Z-.875 F5.
    Y-1.5 F12.
    G17
    G3 X-1.5 Y-1.75 I.25 J0.
    G1 X1.5
    G3 X1.75 Y-1.5 I0. J.25
    G1 Y1.5
    G3 X1.5 Y1.75 I-.25 J0.
    G1 X-1.5
    G3 X-1.75 Y1.5 I0. J-.25
    G1 Y0.
    G0 Z2.M9
    G91 G28 Z0
    G91 G28 Y0
    G90
    M09
    M30
    plese talk slow lol thanks all
    Jan 2009
    103
    Re: arc data error
    Hi slowdigits2,
    when you modified the program to change the width you changed the J values.
    you only needed to change the Y values. I would get in the habit of using decimals
    because some controls would interpret 1 as .0001
    Nov 2014
    74
    Re: arc data error
    thanks for your help mcode so i did as you instructed went a little futher then i noted i had not changed one of the ys thanks for your help i have a few more ?s well probbaly alot lol but the path is running fine thanks again for your help:banana:
  1. error 368 X AXIS : SERIAL DATA ERROR (INT)
    By mattpatt in forum Fadal
    Last Post: 02-24-2023, 02:01 PM
  2. Replies: 12
    Last Post: 03-15-2010, 02:19 AM
  3. 18i-T = 368 B AXIS: Serial data error (int)
    By padobranac in forum Fanuc
    Last Post: 03-16-2009, 12:04 PM
  4. CAM M2- Error 100 tool data not set
    By tomtheslacker in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-25-2008, 05:47 PM
  5. #251 Data Structure Error While In D.N.C.
    By BrianS. in forum Haas Mills
    Last Post: 11-21-2007, 06:23 PM
