586,471 active members*
3,734 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > New 3 axis CNC machine w/1200 ipm rapids released
Results 1 to 7 of 7
    Oct 2005
    8
    Hi everyone,
    We are pleased to announce the introduction of our new 3 axis CNC platform.
    With many features including blistering rapid rates. Much more info here.
    www.romaxxcnc.com
    The website is still a bit rough around the edges.
    A woodworking video magazine has also filmed an extensive article on it as well and soon to be released.
    Thanks, Ron
    RomaxxCNC
    Neat little machine.
    What are you seeing for accuracy/repeatability?
    -Jeff
    Apr 2005
    3634
    Nice looking, machine.
    Apr 2005
    3634
    I just downloaded a couple of your movies, very fast machine!
    What kind of drives do you have?
    Jerry
    Oct 2005
    8
    Thanks for the compliments, we are very happy with the machine and it's performance.
    To answer the inquiries:
    Repeatability/ Accuracy? The machine pictured uses the encoder feedback to track axis position. We have done extensive testing and it will repeat to within +/- .002". The gantry is driven from both sides through one stepper motor via a line shaft equalizer. It is set up for two steppers if one wishes to add another. Our testing showed it was not needed. The stepper motors are 200 oz-in. The Nema 23 steppers are available up to 500 oz-in on the same mounting pattern. Rapids would be much higher. Approaching pick and place performance. Thats speculation though, it's not been tried.
    Drive types? We are using Geckodrives. Of the drive types tested, they were the only one's capable of the high accelerations we were after. Although, we did not test every drive that is available.
    Thanks, Ron
    RomaxxCNC
    What is the availability of the machines.
    David
    Oct 2005
    8
    Hi David,
    We are finishing up a production run of machines and they will be shipping Thursday (10-12-06). Hopefully, We will have stock on a regular basis going foreward.
    Thanks, Ron
