586,277 active members*
3,643 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Nema34 required to get high torque at 30-120 RPM
Results 1 to 8 of 8
    Hi All,
    I have a NEMA34, 878 oz-in stepper motor with features as below:
    • Rate Current=2A,
    • Phase resistance = 3.2Ohm,
    • Inductance= 15mH,
    • Holding Torque = 878 Oz-In,
    • Step angle = 1.8°
    • Wires = 8
    I need to use this with its higher torque at the range of 30 - 120 RPM.
    Today I am using
    Today the motor works, but with very low torque, and at half or thir than the RPM that I set in Arduino sorftware (example: Arduino Speed : 200, real speed : 60)
    Also I have a 36V/350W power supply but I do not want to use after being sure that I will not burn anything
    Attached is the use that I will give to the motor. It is only to wound wet glass fiber, that is very sticky so I need torque to wound it.
    Please any help is welcome!
    Apr 2004
    5740
    Re: Nema34 required to get high torque at 30-120 RPM
    That motor has a lot of inductance at 15 mH. Using the formula: 32 x (square root of) inductance = optimal supply voltage; you get about 124 volts, so running it on 24v (or even 36v) is not going to make it perform too well. If you really want to use that motor and get acceptable speed and torque, you need to get a different driver and power supply. If you want to use that control system, get a different motor with less inductance.
    Andrew Werby
    Website
    oh my!, where should I get that kind of power supply?
    Aug 2006
    2758
    Your 36 volts power supply is a better choice (compared to the 24 vdc PS), make sure the micro-step mode settings on your controller is the same set in your arduino's program in order to get the right amount of pulses/min from the arduino to reach the motor RPMs you want. I am not familiar with your arduino software but somehow it must have an adjustment for the micro-step mode.
    For example at 60 rpm (1 rps), 8 micro-step/step your arduino's pulse frequency should be: 1600 hz
    Arduino's board pulses per second = pulses per rev (200) x microsteps (8) x rev per second (rpm/60) ) = 200 x8 x 60/60 = 1600 pulses/sec = 1.6khz
    kreutz
    Dec 2007
    2134
    As Andrew said, you'd be far better off buying a 280-380oz/in stepper that has very low inductance. There's plenty around with around 2.2-2.8mH cheap on Ebay. This will be far more suitable, give heaps of grunt, and you can still use the existing power supply (although a little more VDC would be ideal).
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    May 2005
    1397
    There is some good info on power supplies at this web page:
    techref.massmind.org/techref/io/stepper/power.htm
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    364
    The RPM's you are looking for are rather low, you only need that high voltage supply for torque at fast speeds. Your driver + supply setup should have plenty of torque at 60 RPM.
    Quote Originally Posted by Fundacion View Post
    Had a quick look at this driver, the 1/2A and 1/2B microstepping settings marked on the cover did sound the "alarm bell".
    This is a TB6600 drive in disguise, the design is crap and only delivers 30% of the potential torque.
    For more info see this thread:
    http://www.cnczone.com/forums/steppe...rive-ebay.html
    A stepper motor has high torque at low speed, the torque decreases when the speed goes up.
    Almost all TB6600 drives manage to kill that low speed - high torque feature of a stepping motor. These really deserve the global award for useless design.
    Use a good driver and your torque will be more than 3 times what you have now.
    Open source CNC electronics and accessories:
    http://users.skynet.be/ldt/CNC%20electronics/THB6064AH.html
    May 2005
    1397
    I strongly suggest listening to Lucas. As the designer of several very good drivers, he really knows what he is talking about.
  1. Coupling ideas for high speed and high torque
    By Azalin in forum Benchtop Machines
    Last Post: 07-24-2014, 11:38 PM
  2. noob question; G540 and high speed Nema34
    By WalkerYYJ in forum Gecko Drives
    Last Post: 09-28-2011, 03:52 PM
  3. Torque-speed curve for Nema34 640 Oz-in (keling Technology)
    By hanschristopher in forum Want To Buy...Need help!
    Last Post: 03-15-2009, 05:09 AM
  4. Need high quality Nema34 Servo that can do 10,000 RPM
    By Kingjamez in forum Servo Motors / Drives
    Last Post: 08-06-2008, 07:57 AM
