586,594 active members*
2,911 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Quick GibbsCAM help I hope.
Results 1 to 6 of 6
    Nov 2014
    10
    I am self teaching myself this program and I am getting things figured out slowly. One thing I can't seem to figure out. I am opening a solidworks model that contains my finished part for a 2 axis lathe operation. All that is getting done is a bore operation. The actual part has a 1.25. bore through it now. How do I set up my material on a part that is imported to have that start hole? Now the rendering of the turn crashes because it is starting the rough bore operation at 0 and not 1.25.
    Aug 2006
    131
    Re: Quick GibbsCAM help I hope.
    If I only have a finished model. I make a copy. Then pull the copy into SW and add stock that roughly matches the raw casting. Once in Gibbs change the proprieties of the solids making one "Part"(finished) and one "Stock"(Raw). It's helpful to make an assembly of the two and orient them so that when you import them into Gibbs they sitting right where you want them.
    Quote Originally Posted by AW-Dyno View Post
    "Teach the ignorant, care for the dumb, punish the stupid."
    Nov 2014
    10
    Thanks for the response, but how do I make one a "Part" and the other one "Stock"?
    Quote Originally Posted by Species8472 View Post
    Nov 2014
    10
    ok...so I think I found how you make one the part and one the stock. But when I run it, it still starts at x 0.0 and not the 1.25.
    I am right clicking on the model and changing the body type from part to stock on the one with the small bore. And making the finished part the part.
    Aug 2006
    131
    Post your .vnc file or a screen cap of your part and the operation dialog box.
    Apr 2009
    1262
    Have you tried to make a new work group and set it as stock using a swept shape as your stock outline? You do not have to import the stock as a solid.
    Best regards,
  1. I hope to be welcome
    By FeGez in forum Community Club House
    Last Post: 10-31-2013, 12:07 PM
  2. my 1st cnc (i hope)
    By boxbuilder10 in forum CNC Wood Router Project Log
    Last Post: 05-28-2013, 02:56 AM
  3. Hope this will be a quick one ....
    By azam1959 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-07-2012, 04:18 AM
  4. Hope someone can help!
    By jaysteel in forum Mach Lathe
    Last Post: 02-11-2009, 04:15 PM
  5. There is hope
    By moldmker in forum BobCad-Cam
    Last Post: 07-30-2008, 11:58 AM
