586,103 active members*
3,446 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Printing blank pages?
Results 1 to 10 of 10
    Mar 2008
    114
    So I have V25 and i made up a couple little drawings I want to print but i get blank pages every time i try to print them. my pc and printer are working fine I can print from other programs. Any ideas what might be wrong? I don't get any error messages, as far as bobcad is concerned it figures it's printing fine. the printer merrily spits out a blank page. In the print preview I see what i want to see. I'm probably missing something really stupid
    Sep 2012
    1195
    Re: Printing blank pages?
    Are you using "Drawing Scale", "1 : 1" or "Fit All" when you get to the printing window?
    Apr 2008
    1577
    Somewhere in the print dialog is a line thickness setting. I don't think that's it necessarily but it can affect the output. Try something a little heavier than "1"
    I don't print from BobCAD but I seem to recall a "print from spool" or something to that effect. Burrman pointed me to that setting and it fixed my printing problem around V23-V24.
    Mar 2008
    114
    I've tried a few different line thickness settings including 25 which is the heaviest possible as well as a few in between 1 and 25. I think I was using fit all in response to the first reply, i need to try every available option apparently
    Sep 2012
    1195
    I'd try one of the other two options to see if anything prints at all. It may be that "Fit All" is too broad for your drawing. You can post the BBCD file (zip it first) if you want us to look at it and see if we have the same problem, but really there aren't a lot of options in the printing system that can be manipulated.
    Feb 2006
    123
    just posted the same thing last night, I've tried everything.
    Dec 2008
    4548
    Quote Originally Posted by SBC Cycle View Post
    but I seem to recall a "print from spool" or something to that effect. .
    It's BobCads print driver conflicting with the print driver in use... In the properties of the printer driver, set it to "print directly to printer" and remove the printer drivers spooling...
    If you are in a multi user production environment, then create a separate "bobcad printer" to make this setting on....
    Feb 2006
    123
    Oh crap it helps if you put a Color cartridge in the printer, I thought I was printing in BW.
    Mar 2008
    114
    Thanks BurrMan that was the solution, it's working properly now. :cheers:
    Apr 2008
    1577
    Quote Originally Posted by BurrMan View Post
    That's it! My memory sure isn't what it used to be. Thanks for clearing that up.
  1. 3D Printing Live! Joining the ranks of the international 3D printing conferences
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-15-2013, 09:20 PM
  2. can not get to command pages (controller issue)
    By hunterbandit in forum Controller & Computer Solutions
    Last Post: 03-08-2012, 04:06 PM
  3. Fanuc 10M Parameter pages
    By tahlinc in forum Fanuc
    Last Post: 01-19-2011, 12:45 AM
  4. FREE PAGES AND FILES (402:100)?
    By adamant in forum Fadal
    Last Post: 01-31-2008, 04:50 PM
  5. missing pages
    By gigi in forum Post Processors for MC
    Last Post: 10-08-2007, 09:43 PM
