586,096 active members*
3,067 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas HA5C4 Rotary table problems
    Mar 2014
    33
    I have an HA5C4 indexer with 4 rotary indexers. We are getting a hi load alarm which means according to the manual a software fuse. The control has been looked at by Haas and they say it is fine. The Yaskawa motor was sent out for repair and no problems were found except new bearings were put in. The cable was megged out and no real issues were found.The indexer works OK and doesn't fault out until it stops and holds a position. It rotates and homes out fine. Trying to find out what a software fuse is. Any help would be great.
    927
    Re: Haas HA5C4 Rotary table problems
    Parameter #52 is the fuse level for rotary axis (A).
    Might check to see what that is set at..different rotaries are set to different levels.
    Change at your own risk. But I have bumped it up a bit sometimes..
    Mar 2014
    33
    I'll try this. We ran it all night on Tuesday and no problems so far. When it would stop and hold at 120 deg the motor would whine but not fault.We'll try to adj. the parameter
  1. HAAS HRT rotary table.... searching
    By AndolsekSLO in forum Haas Mills
    Last Post: 11-14-2014, 01:06 AM
  2. Haas VF-2 w/ HRT 210 ver. P3 Rotary Table
    By sullivnc in forum Haas Mills
    Last Post: 05-30-2013, 11:29 PM
  3. Which Haas rotary table should I get?
    By JeremyMinnesota in forum Haas Mills
    Last Post: 05-10-2013, 12:18 AM
  4. Haas Rotary Table on an 1100?
    By HLF Ordnance in forum Tormach Personal CNC Mill
    Last Post: 04-10-2012, 06:38 AM
  5. Haas HRT 210 Rotary Table Help
    By ME87 in forum Haas Mills
    Last Post: 05-07-2010, 12:53 AM
