New base for the X2. Uses the Mini Mill X2 column and Spindle. Made with Polymer Concretes and Epoxies for structure. Our own Polymer / Delrin glides on fully supported aluminum rails.
Specs:
Swing Over - 8 5/8" with our 2" extender (included)
Travel / Cut Area – X = 26.5”, Y = 8.625”, Z = 9” (to the top of column)
Table Size – 12” x 30”
T-Slot Area – 10” x 24”
Table Slots – 4 raised casting areas to attach T-Slot surface type of your choice
Weight – 115lbs
Acme Screws – 5/8” x 8tpi x 1 start with dual ½” x 40mm x 12mm bearings
Backlash Nuts – 2” Delrin with Buna-N O-Rings for compression
Performance: Components used – 30v Power Supply, Applied Controllers @ 2.6a, 270oz.in. Steppers
X = 90 ipm
Y = 90 ipm
Z = 50 ipm (without offset weights or springs)
We have 8 of these available for end of October delivery.
Prices:
Base without aluminum T-Slot plates - $399.00
Z-Axis - $40.00 w/base
Z-Axis - $59.99 w/o base
Contact [email protected] for orders or shipping quotes. We will have a web site up shortly for taking orders and hopefully real-time shipping calculations.
web Site - CNCBridges.com
Thanks, DeWayne Harlow
