Where do you put the M23 chamfer 'on" code in relation to the G76 canned cycle code? Tried before, after and everywhere... Do I need a P value as well or something else to get this to work? Setting 95 / 96 look fine on the machine BTW... Thanks!
Are you finding that no matter where you put the G23 and whatever you put in Setting 95/96 the machine seems to stop Z while the tool is still in the cut then lift out so it leaves a groove around the last thread? I don't do much threading so I have never looked into this much but I have never managed to get a proper chamfer pullout at the end of a thread.
It seems that there's no difference if the M code is there or not. I'm assuming after the last thread it retracts then comes back to do the chamfer?
Place it in the line before the G76 line.
