586,655 active members*
3,514 visitors online*
    Jul 2005
    195
    Spindle sticking in reverse
    Hi
    My Boss 6.1 doesn't like been use in reverse or forward in the low gear, it sometimes doesn't start first time when you flick the switch and when I come to stop the spindle it quite often carries on running for sometime, upto a couple of minutes at times.
    I guess this is due to dirty contacts if so is it possible to clean them or will I have to buy a new contactor.
    Chris
    Nov 2004
    96
    You can usually take the contactors apart and clean the contacts with some light abrasive material (scotch brite, sand paper, etc). While you are in there, you can check the springs and make sure they are not all gummed up. I think the coils are 110Vac so you can bench test them by applying and removing voltage and making sure they snap closed and open.
    Sep 2003
    552
    I would also check the contact blocks on the manual switch. It sound as if they are gummed up and responding slowly.
    Jul 2005
    195
    I've cleaned them up and there working properly now no delay at all.
    There was some sticky gue on the reverse one and when I pressed it in manualy with my finger (No power on!) it would stick in for a few seconds.
    Cheers
    Chris
