586,094 active members*
3,951 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko 201's with TCNC
    Apr 2003
    159
    Hi Gang can anyone give me a good starting point to set up the motion parameters in TCNC?
    My X axis is giving me headaches, I've replaced the X Gecko unit thinking I'd blown it, but it's OK.
    I get rapids of 160 ipm on Y but X doesnt want to cooperate.
    It is considerably heavier, I was getting good movement but losing step. I know going too fast.lol.Triple checked the wiring too.
    What I would like to know are some good settings to start with.
    Like max. speed (HZ) 40000
    max acc. (HZ) 30000
    max start spd (HZ) 10000
    pulse width (uS) 2
    these are the settings I tried on my machine.Just X axis misbehaves and its running quite free although fairly heavy.
    computer= 200mhz IBM
    steppers #34 4.5v 1.4a sanyo Denki
    48v ps (55v no load)
    1/2 x10 acme rod
    Gantry style cutting area 29" x 15" all metal construction using skate wheel bearings.
    I've tried settings to 60000 doesn't make any difference to Y and Z
    Nov 2003
    244
    try switching the x and y motors to see if there might be a problem with the motor. I have those same motors and they just weren't strong enough. so I found some double stack of the same motor on Ebay and it solved my problem. the amp rating being 1.4a to 2.8a with a brewington driver.
    ...He who makes no mistakes makes nothing! ...
    Tom
    Sep 2004
    Hi Jimini,
    Sorry I cannot help you, but I see that you are getting some very fast rapids.
    I myself have been trying to set up Gecko 210s with very little joy. I am using size 34 double stack motors 2.5v 4.5amps, and they will not run at better than 100mm per min.(4"") at 24v supply. What current resistor are you using?.
    My leadscrews are 2mm pitch and motors 200 steps per rev.
    Apr 2003
    159
    Ivanfinlay
    I have my problems resolved now.
    I'm running @ 55v and the current set resistor is around 13k to give me 1 1/2 amps. It's been quite awhile since I set it up.
    Working very well with Tcnc4.
    I have 1/2 x 10 acme rod and homemade teflon rod nuts, I cut at about 35" min. I have small bits 1/8", 3/32" so any faster tends to snap them with deep cuts in wood.
    I had to mess around with the acc, and start speeds.I also replaced my Z motor size#23, and I was only cutting at 1/2 depth. Turns out it's a 400 step motor, can't stop the shaft by hand, even on the spider coupling body....Jim
  1. Replies: 31
    Last Post: 03-23-2005, 05:04 PM
  2. Gecko vs Rutex
    By samualt in forum Gecko Drives
    Last Post: 10-21-2004, 07:48 AM
  3. Servos or Steppers..... and other gecko related questions
    By UKRobotics in forum Gecko Drives
    Last Post: 04-19-2004, 08:14 PM
  4. To Gecko, or not to Gecko...that is the question!
    Last Post: 09-23-2003, 02:42 AM
  5. GECKO 201's ?
    By ninewgt in forum Gecko Drives
    Last Post: 06-13-2003, 06:49 PM
