PlusBot is a fully working 3D Printer with Build size of
PlusBot Features :
- Highly Stable Design
- 100 Micron Print Layer
- 0.4 mm Nozzle Diameter
- Smart LCD Control Support which allows SD Card Printing
- Can be controlled without a PC.
Technical Specifications :
• Machine size: 450 x 350 x 370mm
• Build size: 220 x 220 x 165mm (LxWxH)
• Nozzle Diameter : 0.4mm
• Layer Thickness : 0.1 mm
• Speed (mm/s) : 60
• Positionning Precision : 27 microns
• Input Format : STL
• Technology : FFF (Fused Filament Fabrication)
• Software : Pronterface (Open Source)
• System Copatibility : Windows 7, Windows 8, Windows Vista, Linux
• Power Supply : 20A SMPS Power Supply,250W
• Weight : 12 Kg
More about the 3D Printer at : http://makemendel.com/3d-printer/plusbot
Checkout the attached Images !!
Looking Forward for Your Views
