586,596 active members*
2,990 visitors online*
IndustryArena Forum > Other Machines > PCB milling > need help with eagle to pcbgcode output
Results 1 to 5 of 5
    Oct 2011
    Hello, I am hoping some folks here use a work flow with Eagle - Pcbgcode and could shine some light on my problem.
    I'm new. I have studied pcbgcode and still can't get it right. Less than 10% of traces are output. Also it shows tool path for milling the board outline, I have the top etch as a ground plane, maybe it is cutting my ground plane, lol.
    I am in no way blaming softwares, I am sure i didn't check a box somewhere.
    eagle pic is what it should look like.
    cambam pic is what I get.
    Anyways, if someone has a minute please download the board file and see what pcbgcode outputs for you, or take a look at the pictures to see if maybe you recognize the problem.
    NOTE: Rename brd file.dxf to: brd file.brd This is an upload work-around, since the Eagle .brd file extension is an invalid type.
    Eagle 6.1
    pcbgcode 3.5.2.11
    cambam 0.9 for viewing paths and editing
    Mach3
    all traces on board are 10mil, clearance 8mil
    my setup for pcbgcode is:
    default .001
    max .008
    step size .005
    tool size .007
    Attached Files Attached Files
    Dec 2004
    1137
    PCB-GCODE Setup General Options
    Explains the PCB-Gcode configurations.
    -Jay
    Oct 2011
    thank you Jay C,
    I have seen your name all over the internet and I hope you continue for the sake of others like me who have wondered just how far they can hurl their laptop.
    The link you gave is one of the most practical I have seen. I had success in less than 3 minutes after clicking it. Let it be a guide for others...
    BTW: here is what worked
    default .0001
    max .0001
    step size .006
    cheers
    Dec 2004
    1137
    You are welcome. Phil's site is what helped me get up to speed with PCB-Gcode and double-sided milling.
    Mar 2006
    38
    Re: need help with eagle to pcbgcode output
    Jay C
    I have been using Eagle and PCBgcode for several years and just had a upgrade for Jave to 1.8. PCBgcode now errors that it needs Jave 1.7. Is there anything that I can do?
    Grandpa Jay
  1. Fun Eagle
    By drawbar in forum WoodWorking Topics
    Last Post: 01-23-2011, 08:05 AM
  2. Eagle CAD importing
    By Blizzy_206 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2010, 05:07 PM
  3. Eagle CAM Processor output - Mach3 Size issue
    By deleteallusers in forum G-Code Programing
    Last Post: 05-02-2007, 03:14 PM
  4. Eagle CAD
    By jhwatts in forum Uncategorised CAM Discussion
    Last Post: 01-26-2006, 11:41 PM
