586,312 active members*
5,178 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Cloudy Aluminum Finish - What am I doing wrong?
Results 1 to 15 of 15
    Nov 2013
    29
    Iam having issues with a Cloudy Aluminum Finish, cant seem to figure out what it could be, here is my setup:
    -1998 Haas VF2 (Very Low Hours)
    -BobCad V26 Build 1335
    -Lakeshore Carbide 1/2" 3 Variable Flute Aluminum End Mill
    -7500RPM @ 50IPM, .007" Finish Pass
    -Tullco PolyCut Coolant
    At first I thought that maybe the coolant was too rich, but its exactly where the manufacturer wants it, ~2.25
    The finish on the inside bore of the part is perfect, but the outside profile has weird cloud lines as you can see in the picture.
    Any help would be greatly appreciated!
    -Geoff
    Attachment 258920
    -Geoff Warner
    VegasCarts.com & myVegasCarts.com
    Aug 2014
    889
    Re: Cloudy Aluminum Finish - What am I doing wrong?
    I hate to say it..................but this looks like the typical surface finish of carbide tools. I'm sure others will disagree, but for aluminum, it's hard to beat HSS.
    Carbide tools aren't as sharp as high speed cutters.
    They last longer and are 2.5 times more rigid, but the molecular structure of carbide limits it's overall sharpness.
    Sep 2012
    1195
    What kind of aluminum? If it's 6061 straight off the machine, I don't think it looks that bad really. How was the inside bore done in comparison to the strategy for the outside profile?
    Nov 2013
    29
    So what would you recommend finishing with? 2Flute HSS?
    -Geoff Warner
    Nov 2013
    29
    Quote Originally Posted by mmoe View Post
    Exactly the same strategy, feeds and speeds.... Hole was roughed and then finished with .007"WOC, Exterior was roughed and finished with .007" WOC.
    -Geoff Warner
    Aug 2014
    889
    It could be the coolant. I know Koolit coolant doesn't leave as bright a finish on 6061 especially if you let it sit and dry up after machining. Did you try just wiping the part off with WD40 after machining?
    Nov 2013
    29
    It definitely doesn't come off with WD40, tried that plenty of times.
    -Geoff Warner
    Aug 2014
    889
    try a different endmill. That may be all it is.
    Nov 2013
    29
    I fixed the problem by increasing my DOC from .005" to .020" and from increasing my feedrate from 50ipm to 67ipm.
    Does anyone see the benefit in running slower feeds and speeds to get a better finish?
    Attachment 259158
    -Geoff Warner
    Aug 2014
    889
    Less rubbing of the endmill on the surface. But from your pictures,I'm surprised the Hass doesn't leave a better finish. You definitely can tell it wasn't a turn part.
    Glad you found a work around it though. I still would of tried a HSS endmill.
    Nov 2013
    29
    Quote Originally Posted by G59 View Post
    The finish is amazing (i only finished the upper portion of the cylinder), Ive seen a lot of billet parts and this is definitely up there with the best finishes Ive seen.
    I plan on experimenting with HSS end mills this weekend.
    Would you go 2, 3 or 4 flute for finishing?
    What feeds and speeds and DOC?
    -Geoff
    -Geoff Warner
    Aug 2014
    889
    I would go with 3 Flutes HSS. Usually you run them at 1/2 the speed and feed of Carbide.
    If you think the finish is great, then just carry on. I'm just making a suggestion here. I'm certainly not telling you to retool your whole setup.
    I think you'll like the fact that the end mills are more than half the price of carbide, and surface finish is usually better and lasts just as long.
    HSS is great, but anything under 1/4", stick with carbide. That's where the extra rigidity really pays off.
    Try this link, great stuff for calculations of feed and speed. FSWizard - Free Advanced CNC Speed and Feed Calculator
    So as you can see the rpm 4968 with 50 ipm.
    Nov 2013
    29
    Im just learning what tooling i need so its not a big deal to buy what I need.
    Ill try it tomorrow.
    Ive heard some people say that a 4 flute HSS leave a great finish on aluminum when finishing....do you have any experience with that?
    -Geoff Warner
    Aug 2014
    889
    4 flutes are good, but I've seen quite a few leave a ripple finish on the part due to harmonics. I know I've experienced it, although the ripples were barely noticeable, with 5 thou vision, you know they're there.
    3 Flutes seem to cancel out the harmonics I had through the spindle and tool.
    It's really up to you and what works best on your machine. Every machine is different, so hard to make a call on that one.
    Sep 2012
    255
    An aluminum-specific Carbide tooling is not worse than any HSS tool in surface finish.
    With a proper tool i normally get mirror-like surface finish at about 0.0025-0.003 ipt chipload
    Whatever marring you see is because of the dull tool.
    These pockets were done at full 1.5" depth of cut with a .5" 2" long 3 flute Niagara Elite endmill. Even at 0.010" chipload and significant scalloping because of very hight feedrate, you can still see reflection of the tool.
    For aluminum when tolerances do not exceed 0.002" i do not even bother to use a separate finishing tool.
    Btw 4 flute endmills are most often designed for anything BUT aluminums. This means they have different rake angle that affects how the chip curls and needlessly increases cutting force, which in addition to higher number of flutes leads to a lot of chatter.
    Sometimes even with very stubby cutters, tool with improper geometry "shivers" or causes more shearing than cutting and produces cluoudy finish.
    Long and boring story short: Use tools designed for the purpose. Generic endmills that claim to work for all meterials tend to not be very good for anything.
    http://zero-divide.net
    FSWizard:Advanced Feeds and Speeds Calculator
  1. How to finish aluminum?
    By jason_n in forum DIY CNC Router Table Machines
    Last Post: 04-07-2016, 01:51 PM
  2. Canned Cycle Finish Starts in Wrong Position
    By JWB_Machining in forum Haas Lathes
    Last Post: 09-20-2012, 08:44 PM
  3. Replies: 10
    Last Post: 12-26-2009, 08:44 AM
  4. Aluminum Finish on an X3
    By pzzamakr1980 in forum MetalWork Discussion
    Last Post: 04-07-2008, 07:40 AM
  5. How do I finish Aluminum?
    By klick0 in forum MetalWork Discussion
    Last Post: 02-13-2008, 07:36 AM
