586,082 active members*
3,658 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > differential encoders with Gecko G320
    Aug 2004
    61
    Hello,
    Can anyone tell me if it is possible to use differential encoders with G320 servo drives? Even if it means using the dif. encoders as ttl encoders if that's possible.
    Frank
    Mar 2005
    361
    you can get some recievers that will convert the diff. signal to single ended. Then they will work fine. Watch not to exceed geckos encoder ma limit if you do then you need a seperate 5volt supply
    mike
    Aug 2004
    61
    Ok thanks Mike. Thats nice to know!
    Frank
    Mar 2005
    361
    Frank
    what type of encoders do you have? I may have some recievers that will work.
    Mike
    Aug 2004
    61
    Hi Mike,
    They are usdigital E5D 1000 count quadriture.
    Frank
