This is a cnc router build. The four motors are up and running fine. I've cut and everything appears to be ok so the outputs are working fine and the board is enabled.
My problem is connecting inputs. I can't get the inputs to communicate so I can wire in the estop, limits, and homing.
I planned on option two from the Mach 3 manual. Pin 10 would be E-Stop, Pin 12 and 13 would be the Z and Y and pins 11 and 15 would be the home switches for the slaved gantry motors (X).
The switches are installed and operate logically with my continuity tester as NC circuits.
I was using an older c-10 without the jumper to pull up/down the inputs and having no luck in getting a response after settting the pins and ports and triggering the switches. I toggled between active high and lo with no effect.
I installed a newer C-10 with the jumper to pull inputs signals up/down with the same results.
Both boards were configured with pins 2 to 9 as outputs.
I'm missing something but I can't see the forest for the trees.
Guy
