I have recently purchased a new 9x20 lathe, and am having problems with it holding parts strait. If I put the shank of and end mill in the chuck and put a dial indicator on it I get a round out of .003”.
I figured that this was due to my high quality Chinese 3 jaw chuck, so I got a new adaptor and 4 jaw chuck from LittleMachineShop.com. I installed the new screw on adaptor and put an indicator its face to check it, and I still have a contour of .003”. You can hand turn the spindle to the high spot, so it is not bearing slop.
I now understand that you have to shim the chuck to eliminate round out. My question is, is it best to make an aluminum shim plate to fit between the chuck and the screw on adaptor, or to try to grind the screw on plate with a tool post grinder?
Pxsi
edit "I accidentally put this thread in the wrong place, is there a way to move it?”
