586,113 active members*
3,235 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas TM-1 Alarm 104 Y servo error too Large
    Nov 2011
    10
    Question Haas TM-1 Alarm 104 Y servo error too Large
    Hey,
    We have a Haas TM-1 and the Y servo keeps coming up with alarm 104.
    We swapped the servos from the X axis to the Y. Y seemed to work.
    Is it a servo problem or parameter issue?
    Also if it is a servo problem and we change it will it mess up our parameters?
    Attila
    Dec 2013
    15
    Re: Haas TM-1 Alarm 104 Y servo error too Large
    After you swap the motors, how is the x motor now?
    Compear the parameters x and y , they should be the same. The only one parameter you have to set is your "grid offset"
    Dec 2013
    15
    Did you try to rotate the ballscrew by hand x and y? How does it fill???
    I'm sure that's not the parameters issue.
    If you send me your parameters together with the serial#I can check it out ,
    Sep 2011
    43
    Not sure if the TM1 servo's have a encoder or resolver, but I have found that this kind of error has been traced back to the (encoder/resolver) in the other machines we've had. Not counting the movement correctly.
    John
  1. A SERVO ERROR TO LARGE.
    By Crashmank1 in forum Community Club House
    Last Post: 07-18-2013, 06:05 PM
  2. Error 187 (M) B servo error too large
    By jimcooptcam77 in forum Haas Mills
    Last Post: 10-03-2011, 05:40 PM
  3. HAAS VF-2 (104 ALARM) Y SERVO ERROR TOO LARGE
    By joanpim in forum Haas Mills
    Last Post: 09-12-2011, 10:24 AM
  4. alarm 105 (z servo error to large)
    By PilzMachine in forum Haas Mills
    Last Post: 03-11-2011, 09:17 PM
  5. Replies: 4
    Last Post: 08-12-2008, 11:01 AM
