Dear Australian CNC people,,
I am having problems with PCI parallel port / cable communicating with Mach3 and my FLA100 router. My motherboard did not have a dedicated parallel port so I purchased a PCI serial and parallel card which claimed to have ECP,SSP and EPP capabilities but I am still having trouble with this I was told that I could alter BIOS to make sure port is dedicated EPP but it turns out this is only possible (Believe) with hard wired parallel ports which are integrated into the motherboard (something which is no longer common) anyway my question is this: Has anyone else had a similar problem and if so how did you fix it? did you; (A) find an old PC with integrated port and use that (B) Find an Australian supplier of dedicated EPP PCI ports that work or (C) Other? Any help would be much appreciated ?
I found this thread from 2007
http://www.cnczone.com/forums/mach-m...port-card.html
"ALERT!!! the card you have is the problem,if it says it supports EPP ECP SSP ect (They even claim to be true printer ports...NOT!!!). then it will be up to windows which mode is active EPP, ECP SSP at any given time (YOU NEED TO HAVE EPP ALL THE TIME!!!)...my motherboard does not have a parallel port so I bought 2 cards like yours (EPP ECP SSP compatible),I could get them to work and even run jobs but I could not get my CNC4PC C3 index pulse card to either work or if it did it was very unstable and in accurate (played with the debounce setting and played to no avail.The problem is that without EPP mode Mach can communicate
but has trouble receiving signals (Index Pulses) "
