586,105 active members*
3,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > cutter comp look ahead error
    Nov 2012
    7
    i need help,I have the following program and subprograms:
    o03936 -> main program
    Code:
    N125 (DEBURR)
    (T10/HEIGHT OFFSET H10)
    T10 M06
    G154 P1
    G00 X0. Y0.
    G43 H4 Z25.4 M08
    M55
    M31
    M98 P3929
    G154 P2
    M98 P3929
    G154 P3
    M98 P3929
    G154 P4
    M98 P3929
    G154 P5
    M98 P3929
    G154 P6
    M98 P3929
    G154 P7
    M98 P3929
    G154 P8
    M98 P3929
    G154 P9
    M98 P3929
    G154 P10
    M98 P3929
    G154 P11
    M98 P3929
    This main program calls -> P3929
    Code:
    T10 M06
    M88
    S6500  M03
    G00 G90 X27.699 Y40.006
    G43 H10 Z25.4 M08
    G00 Z25.4
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 0 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 1 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 2 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 3 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 4 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 5 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 6 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 7 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 8 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 9 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 10 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 11 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 12 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 13 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 14 ]
    M98 P3930 G68 X0 Y0 R - [ 360 / 16 * 15 ]
    G69
    G00 Z50.8
    M99
    This subprogram calls -> P3930
    Code:
    G00 Z25.4
    (DEBURR )
    M98 P3931
    Z25.4
    (DEBURR EDGE)
    M98 P3932     I want to delete this part P3932  because I included it at the beginning of the program
    M99
    This subprogram calls -> P3931
    Code:
    G00 X27.699 Y40.006 Z26.05
    G01 G41 D10 Z15.975 F250.
    Z11.072 F1500.
    X27.229 Y40.233 Z11.142
    X26.926 Y40.33 Z11.125
    X26.519 Y40.425 Z11.062
    X26.111 Y40.514 Z10.994
    X25.703 Y40.6 Z10.926
    X25.294 Y40.682 Z10.858
    X24.884 Y40.761 Z10.79
    X24.473 Y40.835 Z10.722
    X24.062 Y40.906 Z10.653
    X23.65 Y40.973 Z10.585
    X23.237 Y41.036 Z10.516
    X22.824 Y41.094 Z10.447
    X22.41 Y41.148 Z10.379
    X21.996 Y41.198 Z10.31
    X21.581 Y41.245 Z10.241
    X21.166 Y41.287 Z10.172
    X20.751 Y41.326 Z10.103
    X20.335 Y41.362 Z10.035
    X19.919 Y41.394 Z9.966
    X19.503 Y41.42 Z9.895
    X19.087 Y41.44 Z9.822
    X18.671 Y41.459 Z9.749
    X18.255 Y41.479 Z9.675
    X17.838 Y41.497 Z9.605
    X17.423 Y41.547 Z9.546
    X17.021 Y41.671 Z9.497
    X16.656 Y41.881 Z9.462
    X16.343 Y42.165 Z9.444
    X16.097 Y42.509 Z9.447
    X15.934 Y42.899 Z9.471
    X15.856 Y43.312 Z9.514
    X15.867 Y43.731 Z9.573
    X15.972 Y44.134 Z9.647
    X16.156 Y44.506 Z9.725
    X16.422 Y44.822 Z9.816
    X16.744 Y45.082 Z9.904
    X17.119 Y45.256 Z9.993
    X17.524 Y45.345 Z10.077
    X17.937 Y45.399 Z10.151
    X18.35 Y45.434 Z10.235
    X18.762 Y45.464 Z10.324
    X19.175 Y45.491 Z10.413
    X19.587 Y45.515 Z10.503
    X20. Y45.537 Z10.592
    X20.413 Y45.556 Z10.682
    X20.826 Y45.572 Z10.772
    X21.239 Y45.586 Z10.862
    X21.652 Y45.596 Z10.952
    X22.065 Y45.602 Z11.042
    X22.478 Y45.605 Z11.131
    X22.891 Z11.221
    X23.305 Y45.6 Z11.31
    X23.718 Y45.592 Z11.399
    X24.131 Y45.58 Z11.489
    X24.545 Y45.568 Z11.575
    X24.963 Y45.587 Z11.64
    X25.378 Y45.655 Z11.673
    X25.777 Y45.792 Z11.64
    X26.115 Y45.987 Z11.475
    G01 G40 Z13.072
    G00 Z26.05
    M99
    Code:
    X25.333 Y41.949 Z25.44
    G01 Z15.249 F500.
    G01 Z12.709 F381.
    X25.553 Y42.155
    X25.643 Y42.276
    X25.718 Y42.407
    X25.778 Y42.545
    X25.82 Y42.69
    X25.845 Y42.839
    X25.851 Y42.99
    X25.839 Y43.14
    X25.819 Y43.29
    X25.803 Y43.44
    X25.798 Y43.59
    X25.802 Y43.741
    X25.815 Y43.892
    X25.837 Y44.041
    X25.869 Y44.188
    X25.91 Y44.334
    X25.959 Y44.476
    X26.018 Y44.615
    X26.084 Y44.751
    X26.159 Y44.881
    X26.242 Y45.008
    X26.333 Y45.128
    X26.43 Y45.243
    X26.535 Y45.352
    X26.646 Y45.454
    X26.763 Y45.549
    X26.886 Y45.636
    X27.014 Y45.716
    X27.147 Y45.788
    X27.284 Y45.851
    X27.424 Y45.908
    X27.558 Y45.976
    X27.684 Y46.06
    X27.799 Y46.158
    X27.901 Y46.269
    X27.991 Y46.39
    X28.165 Y46.636
    G00 Z25.44
    M99
    But when a delete and run the program receive the next alarm : "cutter comp look ahead error,there are too many non-movement blocks between motions when cutter compensation is being used"
    receive alarm here:
    Code:
    G01 G40 Z13.072
    not recognize G40,if you delete G41 and G40 The program runs without compensation in diameter
    Nov 2010
    73
    Re: cutter comp look ahead error
    Perhaps this line G01 G40 Z13.072 ( This subprogram calls -> P3931) are not sufficient to disable the correction, since there is no move on the x axis or y axis.
    Feb 2008
    586
    You should always turn off comp with an X Y or XY move. Since you have at least 2 Z moves the computer doesn't know how to resolve the turn-off vector. Try inserting an XY move after you bring up the Z the first time (make sure it won't hit anything, too)
    Nov 2012
    7
    Quote Originally Posted by beege View Post
    Quote Originally Posted by andre_77 View Post
    thanks so much for help dear friends.
    I use this piece of code :
    G00 G90 X27.699 Y40.006 and X0 Y0
    and now works
  1. Cutter Comp error with post proccessor
    By Harley95 in forum FeatureCAM CAD/CAM
    Last Post: 03-04-2014, 02:09 PM
  2. G41 Cutter Comp Error
    By thompson_chop in forum Dolphin CAD/CAM
    Last Post: 11-09-2012, 01:42 PM
  3. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-06-2008, 12:30 AM
  4. ProtoTRAK freezing up after cutter comp error with g-code
    By LancoUSA in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-24-2007, 03:12 AM
  5. cutter comp error
    By mikeh78 in forum Haas Mills
    Last Post: 04-21-2006, 06:04 PM
