586,100 active members*
2,627 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Need punch sequencing advice (Amada/Fabriwin)
    Dec 2014
    I need some advice on how to sequence a 30" x 30" square part on an Amada Vipros with part unload automation. I can't seem to be able to sequence the part to eliminate steps as the part cuts out. I can sequence the part to cut out and unload, but I think the way it is sequenced is where I need help. Anybody with some experience with this that can help?
    Thanks in advance for any and all advice!
    Nov 2014
    Re: Need punch sequencing advice (Amada/Fabriwin)
    hi.
    If you are using FabriWin Version 10 just go to Punch Sequence Menu and select Add (you need to asign the tools first)
    Select Add
    Attachment 260158
    Just add the sequence
    Attachment 260160
    Apr 2015
    4
    I am looking for driver for Amada 357 Queen turret press
    with a Fanuc 18P control. I am programming with Fabriwin 6.
    If I need to pay, no problem.
    QUOTE=erickortiz;1608480]hi.
    Select Add
    Attachment 260158
    Attachment 260160[/QUOTE]
  1. Amada Pega Turret punch E Stop Reset
    By supreme_hinge in forum Fanuc
    Last Post: 06-12-2023, 01:45 PM
  2. Amada Punch Retrofit
    By Freecraft in forum Controller & Computer Solutions
    Last Post: 08-28-2019, 08:01 PM
  3. amada turret punch problem
    By bonesclarke in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2019, 07:58 PM
  4. Need Advice on Purchasing Amada Punch Press
    By robd19 in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2010, 05:28 PM
  5. alarma 400 amada coma punch
    By ELFERNYBOY in forum Spanish
    Last Post: 07-02-2010, 08:28 PM
