586,043 active members*
3,574 visitors online*
IndustryArena Forum > Additive Manufacturing / 3D Printers and 3D Scanners > 3D Printer / 3D Scanner Discussion > Heatbed glue needed ??? I'm trying Nylon and it's not sticking !!!
    Jun 2008
    262
    I purchased nylon and have been trying it. When I loaded the filament it was jerky indicating a higher temp was needed. That's all in the rear view now but I'm having a devil of a time with the nylon not sticking to the plate. Is there some physical treatment needed other than a good clean grease free surface? I want the toughness of nylon for a project.
    Thanks for anything!
    i build the braces that keep american teeth straight......tick tick tick
    Dec 2012
    25
    Re: Heatbed glue needed ??? I'm trying Nylon and it's not sticking !!!
    nelZ,
    Try fixing some fine sandpaper to your plate, grit up, and print on that.
    -Davo
    May 2015
    1422
    I used Elmers vanishing purple glue (same as I use for ABS) for a while and it was, well, ok. I ended up having to run the extrusion multiplier out to about 140% for the bottom layer and really smoosh it down.
    I've since laid hands on a piece of single sided PCB from an electronics shop, and drilled an 8mm grid of 1.0mm holes to get it all perforated, then roughed it up with some coarse paper before clipping it to the bed. The layer of copper is facing down and seems to spread the heat a little more evenly, and nylon sticks to it like sh6t to a blanket. ABS still needs glue.
    Look up "garolite" for more info, but I am super impressed with it.
    Jun 2012
    182
    This thread may have some useful information for you.
    There's some useful info here too.
  1. Heatbed and extruder won't heat
    By stargeezer in forum 3D Printer / 3D Scanner Discussion
    Last Post: 07-12-2015, 09:10 PM
  2. holders sticking in spindle
    By poster in forum Uncategorised MetalWorking Machines
    Last Post: 11-10-2011, 02:04 AM
  3. X1 X-axis sticking
    By rincewind23 in forum Benchtop Machines
    Last Post: 04-17-2009, 10:20 AM
  4. HS 1 Tools sticking
    By chucker in forum Haas Mills
    Last Post: 10-29-2008, 05:58 PM
  5. Spindle sticking in reverse
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 10-02-2006, 04:48 PM
