586,388 active members*
3,204 visitors online*
Results 1 to 6 of 6
    Aug 2014
    19
    Collet movement??
    I have been using a collet chuck with an HSK 63 back end and a 25mm multichange tool loaded into it. The collet is 24-25mm and I've tightened it as much as I can. When I use a spanner on the tip and apply some force I am able to turn the tool in the collet.
    This doesn't seem right to me and I would have thought that it was not possible to turn a tool in a tightened chuck... or am I wrong?... I have dismantled the chuck assembly and given it a good clean in the thought that something may be preventing it from tightening properly but the same is possible after cleaning.
    Could this indicate wear on the collet or something else.... I'm a bit reluctant to spin it in the CNC if it may "spin out".
    Any advice would be great.
    Mike
    Feb 2009
    6028
    Re: Collet movement??
    There are many different types of collets. You should also have the torque wrench set up for tightening collets, they last longer, hold better, and don't spring like what I think is happening to yours.
    Is the collet in the HSK installed properly in the nut?
    Aug 2014
    19
    Thanks for the replies, I think it's an ER40 chuck? The collet is sitting neatly in the nut but I did notice it doesn't snap in to the offset ring quite as securely as the others.
    Mar 2012
    109
    Do you have the ability to lock your spindle?
    Aug 2014
    19
    Not sure I'll find out...?
  1. Erratic Z movement AND NO X Y MOVEMENT
    By 05miata in forum Mach Mill
    Last Post: 06-04-2012, 03:10 PM
  2. The collet-held collet holder
    By justgary in forum Tormach Personal CNC Mill
    Last Post: 05-27-2009, 05:20 PM
