Hello forum.
Upon figuring the tool table offsets and applying them, not using g43, thanks guys, I was now set on being able to control my motor from mach3. I read up on it and it seemed very straight forward, BUT, I cannot get my c10 bob to output any signal or voltage change when I turn the spindle on mach3. From what I read on countless manuals and have seen on YouTube, for step/dir control, you just need to enable the spindle, assign the pin for steps and dir, under the spindle tab you enable spindle control with step/dir, then do the motor tuning. I should be getting some signal now out of the c10 from those assigned pins when I turn the spindle on right? Am I missing something?
Also, when I first stated I would set for example 1500 for the spindle amd click the cw f5 button, it would flash and the rpms would show about 1500, a little less. I don't know what I clicked or changed but I don't get any rpm change now, only the light flashing.
Either way, I haven't been able to get any signal from the assigned pins.
Any tips on my issue?
Sent from my XT907 using Tapatalk
