586,119 active members*
3,698 visitors online*
Thread: Rotary axis
Page 1 of 2 12
Results 1 to 20 of 22
    May 2006
    238
    Rotary axis
    Building a 4th axis for the plasma table. Need to get it done fairly quick so i decided to use a trailer spindle and weld on axle.Here are a few pics. Ill post again when its all working
    Jul 2005
    2415
    Re: Rotary axis
    Dave: That is a pretty neat idea! What kind of runout do you think you will see on the hub bearings? If you are using steppers a 10"1 belt reduction would give you pretty good speeds. You need about 30 RPM to do tubing down to 1" diameter and that gives you 10X torque. How do you plan on holding the pipe? At Fabtech I saw several high end pipe cutters and several different support methods for longer pipe. Are you planning on cutting any pipe for joints (saddle cuts, miters etc) ? I will work a deal with you on our PipeFit Plugin for SheetCAM that designs pipe joints in 3D and draws them in SheetCAM as 2D toolpath to use with our Rotary Wizard for MACH
    TOMcaudle
    www.CandCNC.com
    May 2006
    238
    Re: Rotary axis
    Tom,
    I checked the TIR and it was around 3 1/2 thou.Most of the runout is in the 4 jaw chuck but not to bad for a 140 dollar 8 inch chuck. I currently have 7 to 1 reduction. This setup will be mostly be cutting short 2x3 tubing like the pic. Those tubes are turned in a jig three times. I just got the sheetcam rotary plugin and its pretty impressive. I would def be interested in your pipefit plugin. Im going to build a stand alone round tubing cutter with a smaller 3 jaw chuck for that.Got the ground strap done today and hoping to cut and bend the sides tomorrow.
    Dave
    Nov 2012
    64
    Re: Rotary axis
    Nice work! look forward to the updates :cheers:
    Looks like a crafty way you have rigged up to cut those in the pic, I will have a try at that.
    Nov 2007
    343
    Re: Rotary axis
    Now there is an innovative plan. I too will be watching for updates on this thread - great job! The cuts on that tubing look great - do I understand that you had to reposition them three times? If so the stops and starts look very nice.
    May 2006
    238
    Re: Rotary axis
    So this is the fixture. you take out the slats and bolt the jig to the side rail. The rails are cut with the top of the tube just out of the water. Rotary should save lots of time on these.
    Nov 2012
    64
    Re: Rotary axis
    It's an option I hadn't thought of before though, thanks for the info.
    May 2006
    238
    Nov 2012
    64
    Re: Rotary axis
    You soon got to grips with that, nice job the wheel bearing looks right at home in that unit.
    Jun 2009
    55
    Re: Rotary axis
    What shield is on the torch?
    May 2006
    238
    Re: Rotary axis
    It is a finecut shield
    Jun 2009
    55
    Re: Rotary axis
    Thanks.
    Jun 2009
    138
    May 2013
    53
    Re: Rotary axis
    NIce!
    May 2006
    238
    Re: Rotary axis
    Got all the parts together and started cutting tubes.Made a quick adjustable roller to support the end of the tube. Im happy with the rotary axis.Here are a few pics
    Sep 2011
    54
    Re: Rotary axis
    Looks great Dave. I like the rollers. It looks like you could make a few extra and clamp or screw them on to the slats for longer tubing. Thanks for sharing.
    Jul 2005
    2415
    Re: Rotary axis
    Quote Originally Posted by dnelso View Post
    Dave: Contact me off list. I have a DEAL for you!
    TomCaudle
    www.candcnc.com
    Sep 2007
    18
    Re: Rotary axis
    Nice design and build. Where did you get your belt reduction pulleys?
    May 2006
    238
    Aug 2008
    1186
    Re: Rotary axis
    What an awesome design to build to use thread! Very cool in indeed! Kudos for innovation and use of available parts.
    Sent from my XT1080 using Tapatalk
Page 1 of 2 12
  1. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  2. Replies: 1
    Last Post: 06-23-2013, 05:02 AM
  3. Auto align B-axis (rotary axis) using probe
    By pwilson101 in forum Parametric Programing
    Last Post: 02-06-2012, 02:53 AM
  4. Replies: 1
    Last Post: 01-14-2012, 06:22 PM
  5. Tipping rotary haas rotary axis
    By mfpuller in forum Mastercam
    Last Post: 04-04-2011, 04:16 PM
