586,075 active members*
3,691 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Retain defaults in profiling, pocketing etc dialog, being able to enter defaults
    Dec 2011
    30
    Most of the time I am following a fixed plan: 5mm cutter should cut 1mm deep, not the default 0.77, use ramp=2° and zero radius approach etc.
    Since there is no option to specify defaults, I have to reenter all of this again. Would be nice if you can specify a default per cutter and dialog (profiling, pocketing etc)
    Or at least keep the last used value even after switching to a different cutter.
    Apr 2003
    1357
    Re: Retain defaults in profiling, pocketing etc dialog, being able to enter defaults
    I would suggest you create templates with your desired parameters present, or create some macros with preset values. Like this:
    https://www.youtube.com/watch?v=Wkq4kLpGAaU
    or like this:
    https://www.youtube.com/watch?v=7MoYV6Vfgg8
    See if these videos help.
    Dan
    Dec 2011
    30
    Hmm, not a bad idea. Trouble is though, that I have 30 layers for each cutter. So I would need a way to have one layer as template to load the cutter information and based on that create new toolpaths/layers, no recalculate.
    Let me give you the big picture.
    I want to cut the outer area and the inner area. Since I have to define which closed curve is inner/outer in the 2D case, that asks for two layers already. No problem. What is worse however, here I selected all the inner curves and placed the cutter on the inside and as you see, sometimes it is inside as it should but on the left hand side it is outside the curve. As a result I have the tendency to have one layer per curve.
    But even if that would work perfectly, do avoid spending times with travelling from one to the other, I would still mill closely placed objects only. Hence end up with multiple layers for the same operation. I could copy the layer of course an do a recalc model.... no I cannot as the recalc is based on the curve it was originally built for.
  1. defaults
    By KS Cowboy in forum Visual Mill
    Last Post: 12-07-2011, 05:21 PM
  2. Setting the defaults in v24 to mm
    By nivlek in forum BobCad-Cam
    Last Post: 01-19-2011, 11:04 PM
  3. SprutCam Defaults
    By Magnum164 in forum SprutCAM
    Last Post: 01-12-2011, 12:03 AM
  4. set defaults in SW 2008
    By Les George in forum Solidworks
    Last Post: 02-07-2010, 02:57 PM
  5. X4 Operation Defaults
    By WingNutz in forum Mastercam
    Last Post: 12-31-2009, 04:29 PM
