So I have a Super Kia Turn 15LMS. Fanuc OiTB control. Just mustered up the courage to start running (I am coming from a Fadal 4020, so this is a little more intimidating to me)....
Anyway - I am having a Q-setter problem, and I might have a problem with the machine zero's....
When I touch off on the tool setter in X, I get an offset value of like 10.xxxx using a standard turning tool..... When I go turn off some stock, measure diameter, X (dimension), measure, and I'll get like a -4.xxx which is exactly right....
Z direction- no problem. Works fine.
What would make the tool setter do that?
Only value I have in my G54 offsets is the work offset in G54 (1).
Pic attached of my machine when it is zero returned. Isn't the machine supposed to be zero at the Z-axis centerline and not at the zero return position?
Attachment 260578
