586,080 active members*
3,563 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Poor finish on a Mini Mill SS
Page 2 of 2 12
Results 21 to 38 of 38
  1. #21
    Feb 2011
    605
    Re: Poor finish on a Mini Mill SS
    Still think there is something wrong with the machine. 2500mm/min feed is under 100IPM, that should be no problem, there's plenty of video of Mini Mills cutting at that feedrate and making good parts. What is the depth of cut for the finish pass?
    If those are the roughing passes and you haven't done a finish, then yeah you might be pushing it hoping to have usable surface finish after some heavy slotting.
    PM-45 CNC conversion built/run/sold.
  2. #22
    Feb 2010
    1184
    Sorry if I missed this fact, but is the machine still under warranty?
  3. #23
    Jun 2010
    60
    Quote Originally Posted by jid2 View Post
    That is a finish cut. 0.25mm deep.
  4. #24
    Jun 2010
    60
    Quote Originally Posted by haastec View Post
    Sadly, no Sir
    Build date is end of 2010. Sold new Jan 2011
    We now have the Haas agents on the way with a renishaw ballbar
  5. #25
    Jun 2010
    60
    The **** thing is we can't even sell it anymore. Not with good conscience anyway.
    We have to fix it.
    If only someone knew how
  6. #26
    Feb 2010
    1184
    Quote Originally Posted by Aquatic View Post
    The ballbar will tell you a lot.
    Good luck! Hopefully you can get this sorted out soon.
  7. #27
    Jun 2010
    60
    Fingers crossed.
    With the ballbar info the locals can approach Mr Haas himself and try get a solution
  8. #28
    15362
    Sadly, no Sir
    They should be doing a Vibration Test first, if that is ok, then do the Ball-Bar Test,the Vibration test will tell them if the spindle & spindle motor are within spec, (Bearings Etc) this needs to be the first Test
    So you got the machine 4 years ago, was it just sitting all that time doing nothing,& this was the first job you tried on it, in most machine shops it would of payed for itself in that time
    Mactec54
  9. #29
    Jun 2010
    60
    Spindle and head are good. Tests done
    The shudder happens with the spindle off
    We bought the machine used 2 months ago from the original owner. It has more than 1500hrs but less than 2000hrs on it. The motherboard has been swopped out 1500hrs ago
  10. #30
    15362
    Aquatic
    I wonder if the first owner had a crash & damaged the ball screws, anything is possible, Yes I know they said it had never been crashed ! 1500 hrs & you paid how much, thats far from new
    When they changed the Motherboard, the machine parameters may not have been installed correctly, this to could cause the problems, you have had also
    It's easier for responders, if you tell the whole storey in the first post
    Mactec54
  11. #31
    Feb 2010
    1184
    What was tested to make you say "spindle and head are good" and how?
    What did the ballbar test reveal?
  12. #32
    Jun 2010
    60
    Aquatic
    There is damage to the rear Y axis cover. But nothing that looks like it could have caused damage to the ball screw. I did ask this question of the technicians and they said all was good. If something had have happened the coupling would have been damaged.
    The Haas agents have taken our parameters and compared to factory settings. Spot on.
    The price is the going rate for that machine here in Australia. A new MiniMill S2 is just shy of A$100000.00
  13. #33
    Jun 2010
    60
    I wasn't present when the spindle was tested. So can't answer the how.
    The shudder is there when running a program with the spindle off.
    It's not the spindle!
    Ball bar test should be today I think. I will post results when I get them.
  14. #34
    Sep 2011
    43
    About 15 years ago I bought a new Daewoo VMC 4020. When we took a couple of test cuts on some 6061t6 aluminum we experienced the same thing. I had the Daewoo tech come out and they replaced the spindle cartridge. Tried it again same thing. This time they sent a Daewoo factory representative from New York to look at the machine. He replaced the spindle and same thing. He took at the spindle and they had it dynamically balanced and put it back in. Been fine for the last 15 years.
    John
  15. #35
    Jun 2010
    60
    Still no ballbar test. Not sure why no one has pitched yet :-(
  16. #36
    Feb 2009
    6028
    Man, even the top looks horrible. That looks like a loose spindle there.
  17. #37
    Jun 2010
    60
    A bit of an update.
    Alfex, local Haas agents have gotten involved and done a whole bunch of tests. 4 visits later. The machine has been level check at every visit. They have admitted that there is definitely something amiss. That in itself is a win for us.
    However they have no idea on how to fix it. Packets of data have been sent to Haas USA on 3 occasions now. And still no solution. Seams it has stumped everybody.
    What they did today was swap out the Y axis motor and encoder with the std minimill on the premises. The technician did a test on the motor while in it was off the machine and apparently the shudder was very obvious. (I was not there)
    While the motor was out the torque on the front mounting bolt was checked. 1/4 turn!!! That's a lot if you ask me.
    I got there once it was all back together with the swapped out Y motor and cut a test piece. Not 100% fixed but a huge improvement. The cabinet door no longer rattles when jogging in X and Y.
    So more data off the the states tonight. Lets see what they say on Tuesday. Alfex have also offered 2 brand new motors to install and test.
    I am a little happier that we have some progress. Until the invoice arrives :-(
  18. #38
    Jun 2010
    60
    My luck has changed! Hopefully 0000
    Same machine today top photo, old part 2nd photo.
    Day and night
    No more dips in Z
    No more shudder in XY
    Still a slight mark at a change in direction. But I cannot feel it with my fingernail
    All I can say on the fix is changes to parameters
    303, 750, 753, 884, 885, 886, 900, 901, 902
    All have to do with the signal being sent to the motor. The stuff you see on an oscilloscope.
    Waiting for the full report from Haas. I will report back once I have this.
    Tried to convince the technician that he should not charge us as we have offered our machine up as a fault finding learning opportunity. 0
    Don't think he fell for it!
    Has to be one of the best Mondays in a LOOOOONG time
Page 2 of 2 12
  1. Poor Finish on new machine
    By J Monty in forum Knee Vertical Mills
    Last Post: 04-11-2013, 01:23 AM
  2. Poor quality finish
    By NylonAdmiral in forum MetalWork Discussion
    Last Post: 04-27-2012, 06:05 PM
  3. Poor finish
    By LLDesigns in forum Benchtop Machines
    Last Post: 07-02-2011, 01:56 AM
  4. poor surface finish
    By sinha_nsit in forum CNC Tooling
    Last Post: 02-17-2010, 04:48 AM
  5. Poor surface finish
    By pmsmichelle in forum Mastercam
    Last Post: 02-05-2010, 03:54 PM
