586,035 active members*
3,790 visitors online*
Results 1 to 7 of 7
    Nov 2014
    7
    Question Correct Zero position
    Hi everyone maybe this is a dumb question, and i'm sorry if it is, but i really not sure.
    which one is the correct (0,0) position?
    i saw a video which said it's the first image.
    can you help me?
    Attachment 260674
    Re: Correct Zero position
    2nd image, but technically, it can be anywhere you want it to be.
    Service SCM BR Guest
    What the model of machine?
    Via iPhone of the Tapatalk
    Nov 2014
    7
    one that i built myself
    Now understand. You use encoder incremental or absolute?
    Nov 2014
    7
    i'm new at cnc and i'm not sure what are you asking, but can i tell you that i'm using stepper motor directly connected to the ball screw, i'm using gecko drive g540 as controller for the steppers, and i'm using a hitachi m12vc router for spindle.
    I not recommend engine stepper for the axes how XYZ, B or C i recommend engine stepper only tool change. For the axes use servomotor with encoder or magnetic tape.
  1. spindle not orientating to correct position
    By Ph2011 in forum SIEMENS -> GENERAL
    Last Post: 05-03-2014, 11:28 AM
  2. Loosing the correct position.
    By Johanan in forum Machines running Mach Software
    Last Post: 01-09-2014, 08:27 AM
  3. Position Page and Relative position
    By tnik in forum Haas Lathes
    Last Post: 11-03-2012, 06:37 PM
  4. losing position, lots of position
    By cyclestart in forum LinuxCNC (formerly EMC2)
    Last Post: 01-24-2010, 08:50 AM
  5. Replies: 4
    Last Post: 10-28-2009, 06:39 AM
